Question about Royal 15MX Shredder
Motor runs but shredder is jammed - Royal 15MX Shredder
    Problem Solver:
  • 8 Answers
Check for broken plastic gear
Posted on Nov 08, 2014
2 Suggested Answers
  • 883 Answers
SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Posted on Jun 21, 2007
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
The motor on my shredder does not run smoothly anymore. The motor is pulsing. This started when I think I feed the machine too much paper.
Turn off power and turn the shredder upside down. Check for paper shreds jammed in the shredder wheels. Remove all that remains. If the motor continues to pulse, you may have damaged the drive mechanism
Jan 02, 2013 | Office Equipment & Supplies
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
The motor on my shredder will only run in reverse
You need to remove the top section, make sure it's unplugged, and use a tweezers or very narrow needlenose pliers, and pluck out any paper chunks, and use canned air to blow out the paper dust. Reverse only means the chopper thinks there is paper jammed inside and will only run in reverse to clear the jam.
Jan 31, 2010 | Aurora Electronics AS662C Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Staples SPL-1506X
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Jul 05, 2008 | Office Depot Ativa DQ60M Shredder
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
Royal 15MX Shredder Logo
88 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
