Question about Garden
Firestone rototiller parts
I need a picture of the forward and reverse belt lay out on firestone rototiller 8-d-420 or 422-8-250
4 Suggested Answers
SOURCE: looking for owners manual
I have a manual for the Wizard 5HP tiller. The reverse belt basically makes a figure 8
The belt goes over the motor pulley and over the idler pulley then makes a twist in the middle and around the bottom pulley. This cause it to basically rotate the opposite direction from the rotation of the drive pulley
Posted on Jun 10, 2009
pippall
  • 1486 Answers
SOURCE: roper rally rototiller wont till
Check belts
Posted on Jul 06, 2009
SOURCE: sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Posted on Sep 07, 2009
My craftsman rototiller shifts really hard
Check the oil in the transmission.
Consider getting a service manual for your tiller.
www.searspartsdirect.com/partsdirect/brands/Craftsman-Parts
Jul 01, 2014 | Craftsman Garden
I need to no the belt size for the v belt on a scott rearline tiiler the model number is 6070s
This is what I found
Forward belt is a 1/2 by 27 (L4270 or 4L270, Oregon 75-427 )
Reverse belt is a 3/8 by 30 (L3300 or Gates FHP 3300)
May 30, 2014 | Ardisam 5.5 Hp Rear Tine Rototiller
I have a very old Wizard (Western Auto) Front Tine Rototiller Model gis 6990 A27 with power reverse. I am looking for a manual or a diagram of the drive belt routing. (Patent #2903077). Any assistance...
Hi and welcome to FixYa, I am Kelly
Here is a picture of the belts installed.
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
NOTE the front fwd direction drive belt / closest to the motor is installed like any other belt. The rear belt for REVERSE direction has 1/2 twist. The idler pulley presses in for foward driving and pulls out against the reverse drive belt.
This should be what you need.
Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | Garden
How to change belts on older troy built rototiller
Make sure the belt tension is adjusted before you change the belts. at the bottom of the forward and reverse lever you will see and small wheel that rides on an adjustment plate. On the front side of that adjustment slide is a 9/16" bolt. Loosen that bolt a bit and tap the adjustment slide down a bit, maybe a 1/8 inch. That should adjust the belt tension so you dont have to till with one hand while holding down the direction lever. Hope this helps.
Apr 10, 2010 | Garden
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I need a forwward cable for an earthquake reartine rototiller #5020dm how to order. thanks
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
Oct 02, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Need a belt diagram
Forward belt is a 1/2 by 27 (L4270)
Reverse belt is a 3/8 by 30 (L3300)
Apr 09, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
