Question about Kenmore Sewing Machines
Feed dog won't return to up position - Kenmore Sewing Machines
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 185 Answers
SOURCE: problem with trac feeds
When you drop the feed dogs on most modern machines they do not return to the up position until the motor rotates one full turn. Your feed dog will then be up and ready to use.
Posted on Feb 28, 2008
mohammed387
  • 1952 Answers
SOURCE: feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Posted on Aug 26, 2009
  • 109 Answers
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Posted on Aug 23, 2010
  • 300 Answers
SOURCE: I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Posted on Sep 07, 2012
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Bernina feed dog down and will not return to normal position by switch
1. Clean and lubricate entire machine following the MANUAL instructions.
2. Try to "lower" it again then try to raise it - several times.
If this does not solve it, see a service person.
Jul 08, 2014 | Bernina 1008
Feed dogs do not return to up position
manually rotate the handwheel a few times after deselecting the feeddog drop. if this doesn't work, take the machine to an authorized Viking for evaluation.
Apr 16, 2014 | Husqvarna Sewing Machines
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
Feed dog won't come back up
Try jiggling the hand wheel as you push/slide the feed dog button.
Dec 20, 2012 | Sewing Machines
Aug 28, 2012 | Brother PC-420
I put the feed dogs down and now they won't go back up, what do I do now?
Feb 11, 2012 | Baby Lock Ellure
Problem with trac feeds
Dec 28, 2007 | Sewing Machines
Feed dog is stuck
May 07, 2007 | Singer 2662
Sewing Machines Logo
12 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
