Question about NEAT Receipts Mobile Scanner
Neat receipt mobile has black line - NEAT Receipts Mobile Scanner
How to remove engine cover 2011 Rav4 ?
Use a torques bit. Looks like a star pattern screwdriver.
May 16, 2014 | NEAT Receipts Mobile Scanner
Neat receipt scans a black line through part of the page
That's all I got was a black strip. My solution was to get a new Neat Receipts mobile scanner. It works great and I didn't have to make any software changes. It was worth the price for a new one compared to all the hassles I had with the old one.
Mar 29, 2014 | NEAT Receipts Mobile Scanner
Blank scan with neat desktop scanner
Connect the scanner to a different computer.
If you get the same result, then the scanner is "dead".
It's moving the scanning-head, but not detecting (or not transmitting) any "non-base-line" information.
Either that, or you have changed the CONTRAST and/or BRIGHTNESS settings to "wash-out" the image -- like looking at a "cream" coloured piece of paper in bright sunlight -- it may look "white".
Feb 03, 2014 | The Neat Company NeatDesk Desktop Scanner...
Why would my 'copies' be coming out black pages on Neat Receipts portable scanner; prior to cleaning they were heavily streaked with black lines...now totally/heavy black.
A high percentage of scanners that people use at home are made by Visioneer, although they may be labeled and sold by other companies. Xerox is one example. The Visioneer software drivers are sensitive to changes that routinely occur in MS Windows from software installations, updates, etc. On this Visioneer webpage the company says, in describing the problem, "Your scanner does not appear to be functioning normally; you are getting errors when attempting to scan, your images are not easily readable, or you are unable to access the scanner properties." and "Problems may arise after you have made changes to your Windows environment (e.g. you installed Windows Updates, you installed another scanning application, etc...).".
Instructions as well as some software utilities are available for free download on the same page. Of course this won't help if something has actually broken on your scanner, but they're pretty durable, and chances are you can fix it by closely following the instructions from Visioneer.
This answer should apply to several of the questions in this section.
Jun 22, 2013 | NEAT Receipts Mobile Scanner
Lost my neat cd
if that is an old CD then don't worry here you have an upgraded version so try this it will satsify you and you have some more here in the same link just try to go throught them and have an useful time all the best
The link is
http://www.neat.com/support/downloads
Audi parts
May 23, 2012 | NEAT Receipts Mobile Scanner
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
NEAT Receipts Mobile Scanner Logo
37 people viewed this question
Top NEAT Office Equipment & Supplies Experts
Steve F
Are you a NEAT Office Equipment and Supply Expert? Answer questions, earn points and help others
