Question about Samsung SCH-U380 Brightside Verizon Phone - Black
Svc on a Samsung Brightside SCH-U380 - Samsung SCH-U380 Brightside Verizon Phone - Black
3 Suggested Answers
  • 13 Answers
SOURCE: sch-u380 map app
www.sygic.com/
Posted on Oct 01, 2012
Testimonial: "Thanks for the suggestion but it is not a free app unless you go to google play & it doesn't support the phone."
SOURCE: how to disassemble the Samsung brightside cell phone
Don't know if you were able to get this done but I needed to take apart the lcd screen on mine and replace it. in order to get to it you need to start from the back and work your way up to the front.
Tools:
-preferably a #000 philips screwdriver
-not necessary but I also used a 3/64 flathead screwdriver
1. Take battery cover off.
2. Take out battery
3. Take the #000 phillips screwdriver to take out the six silver screws.
4. Now take out the two black screws that were behind the battery.
5. Slide the phone out now in order to get better leverage to take off the plastic case that protects the circuit board.
6. Now there will be a ribbon cable connected to the circuit board. just pull it off. The cable actually snaps on so all you need to do is pull it off, there is not a locking mechanism for this.
7. you can now take the circuit board off to see the back side of the qwerty board and the slider. remove all of the silver screws on the slider.
8. Now the slider can come off, to make it easier, take off the ribbon cable that is fed through a slot on the slider. The ribbon cable is connected to a square, the square is stuck to the plastic piece by tape and will not hurt anything as you pull it off. Once that is off you can now fee the cable out of the plastic piece that was connected to the slider in order to get it out of the way.
9. Now there are 4 black screws on the back of the lcd cover. take them out.
10. This is stuck on pretty good and I had to use a small flathead screwdriver (I used a 3/64 flathead) and a lot of fandangling to get this piece off.
editor's note: I replaced the lcd so I'll just explain how to do that. I don't know if you needed the window replaced or if it was the lcd.
11. From this point the ribbon cable's port is blocked by a bluish tape. peel that off, and you should be able to see the locking mechanism which is a black bar on the opposite side of the ribbon cable. lift this black plastic bar up and the cable will pull right out. There are two other ribbon cable's on the left side of this port where you will need to do the same thing. These two other ports have the same locking bar so make sure to lift it up before taking the cable out.
12. Last step, the lcd screen is not connected but stuck to the bottom by a tape or some sticky substance. I took my flathead screwdriver and just peeled it off.
13. That was the last step, should be self explanatory from here, just work your way back and make sure all those ribbon cables are snug. I hope this helps, I noticed no one had made a video or made any responses from what I could see toward this subject so after successfully doing this I hoped I'd be able to do someone some good. Peace!
Posted on Dec 12, 2012
How to reset/delete unactivated U380 Lock Code for new use?
you just have to go to a mobile repair shop and ask that guy to install a fresh copy of the software that your mobile phone is required
Dec 09, 2015 | Samsung SCH-U380 Brightside Verizon Phone...
Touchscreen will not work on my Samsung Brightside SCH-U380
Other than a bad digitizer (touchscreen) or connection, sometimes just a tiny bit of gunk/debris gets in that tiny gap that goes around the outside of the screen. That often results in the same problem,, a non-working touchscreen. Take a very thin edged piece if cut plastic as a "tool" to clear out gunk/debris from this gap around the edge of the screen. Some people even have used like the opposite end of a sewing needle (not the pointed end).
Many ppl have fixed a non-working screen simply by cleaning out this tiny edge gunk. Give that a shot as a first step. If you use care, you won't damage anything.
Oct 28, 2014 | Samsung Verizon Brightside Sch-u380 Black...
Samsung flash
No. Verizon is CDMA. T-Mobile is GSM.
Aug 24, 2014 | Samsung SCH-U380 Brightside Verizon Phone...
Master reset
www.youtube.com/watch?v=Ph6Vc4FccQo
Mar 15, 2014 | Samsung SCH-U380 Brightside Verizon Phone...
I forgot my password and my phone is not registered
You can do a reset:
- power off
- power on while holding volum up and home keys
- select reset
NB: all your contacts and messeges will be lost
Jan 08, 2014 | Samsung Verizon Brightside Sch-u380 Black...
My calls can't be heard on other phone
The problem is mouth pins problem,therefore go chage mouth pins
Jun 25, 2013 | Samsung SCH-U380 Brightside Verizon Phone...
Samsung brightside will not turn on.
If the phone lights up when you plug in the charger it is probably the ribbon cable that flexes every time you open the keyboard. About 25 bucks from cellphonerepairshop.com. Be sure to flip up the little latches on the flex cable ends before attempting to plug or unplug the cable ends.
May 26, 2012 | Samsung Verizon Brightside Sch-u380 Black...
Samsung SCH-U380 Brightside Verizon Phone - Black Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
