Question about Home
I have a danze DA603566 with no hot water presure
Danze sunflower shower head only works with cold water
Hi, same problem i had faced and that time i didn't have much knowledge about pipe setting or plumbing stuffs.Please check the shower setting connections and make sure the hot water is in active mode or check the internal connection for pipes with faucets.i have given link for more information for showers .
http://www.a-general.com
Jun 10, 2014 | Danze & Sunflower Showerhead
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
May 18, 2014 | Danze Home
Danze shower no pressure except extrememly hot
these systems have a temp limiter and it sounds like thats your problem...pull off handle and see if that part is broke or binding...if so replace or reset...good luck
Jan 01, 2012 | Danze 20 X-plode Sport Fish Home
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
