Question about Silicon Power Luxmini 720 32GB USB 2.0 Flash Drive - Metalic Design, Bronze
My computer can't read usb drive - Silicon Power Luxmini 720 32GB USB 2.0 Flash Drive - Metalic Design, Bronze
    Genius:
  • 1,554 Answers
Try the connector on the back of the computer
Posted on Jun 19, 2014
Why my computer is not reading lacie cookey usb
your usb key may have failed or it is in a different format that your pc cant read
Mar 24, 2014 | LaCie Cookey Flash USB Key - 32GB
My pyle pl88mu its not reeding the USB flash driver everything else works fine but the usb its not working and i tried with 3 different USB's
  • Typically these units can only read FAT32 formated drives. check to make sure that the drive is formated FAT32.
  • You can insert the USB drive in to your computer. Go to Start -> My Computer then navigate to the USB Drive. Right click on the drive and view properties. Check under file system. If it says NTFS please continue reading.
  • You can format your USB medium on your PC to FAT32 then copy your media (music) to the the USB drive.
  • Insert your USB Drive to the PC On your PC navigate to Start ->MY Computer Then locate your the drive that is your USB Drive. At this time you will want to save any of your data before continuing. All Data on the USB drive will be lost. Next ensure that you have selected the correct drive.
  • Right Click on the drive on go to format... Under File System select FAT32. I would suggest leaving Quick Format unchecked. So you ensure that will information is removed. Then Click start. Next copy your media (music) back to the USB Drive.
  • Try inserting back in to your stereo.
Hope that helps, don't forget to vote.
Nov 16, 2010 | Pyle PL88MU
USB drive does not regularly read the USB flash
I have a Designer I USB that suddenly started not reading the usb stick that came with the machine. I was terrified that my machine was going bad, but I always start with the cheapest solution first. I bought a new usb stick, loaded the designs from the old one into my software then loaded everything on the new usb stick. My machine reads it every time so far. I replaced the usb stick about 3 months ago and have not had another problem since. I don't know if this is your problem, but usb sticks can go bad and since they are so cheap, I would try this first.
Jul 11, 2010 | Husqvarna Designer I
My computer says it doesnt recognize
Phyllidee, It may be possible that your PC is not reading the pen drive. use it on a computer/laptop that reads it and backup the data there. Then format it and insert it in your computer. If need be then format it in your computer. If it does not work anywhere then, obviously, the pen drive is bad.
May 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
NO READ COMPUTER
Try plugging this device into another computer. If it still doesn't work, the device has died.
If it does work, the computer that won't read this device probably has usb driver issues or usb hardware failure.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I reformat the flash drve and i plug it in my laptop my laptop
Hello, Is it on any computer that your flash drive cannot be read?
Try putting the USB flash drive into a different slot USB on your computer.
There could be a number of reasons for this problem.
Here's a related article that might help: http://ask-leo.com/why_wont_my_system_recognize_my_usb_device.html
Nov 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SanDisk 4GB thumb drive not recognized by my computer
Try any other computer but not open drive only see if they can read it. Also change USB port, sometimes some ports dont accept devices. Also check for latest antivirus software last such case viruses dont let me read any of my USB drives. If driver works to oter PC then you have virus.
Aug 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The computer doesn't read the flash drive when i plug it into the USB port
go to my computer property then hardware then device manager then uninstall usb drivers and install again
if u find unknown device u must have to install proper flash drive driver
May 22, 2009 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
My 2gb kingston usb flash drive cannot open / read to any compute
There are several USB recovery programs available. While I don't endorse any one in particular, I tend to stay away from "free" ones, since I believe in the axiom "there's no such thing as a free lunch" since you don't know what's in it for them.
You could try this company, which advertises a free download (but I suspect they are really a shareware company so it's possible that they will want money for a more expansive version) which may make it possible to fix your drive in one instance at least.
If this data is important to you, it's probably worth spending 30 or 40 dollars to avoid a repeat.in the future, because USB drives get corrupted from time to time.
Anyway, here is the link:
www.premiumdatarecovery.com/
Good Luck and If you find my assistance valuable, please give me a rating.
Jan 22, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Silicon Power Luxmini 720 32GB USB 2.0 Flash Drive - Metalic Design, Bronze Logo
48 people viewed this question
Top Silicon Power Cameras Experts
Are you a Silicon Power Camera Expert? Answer questions, earn points and help others
