Question about GE Profile Harmony DPGT750EC Electric Dryer
I have a ge profile electrice dryer, it heats ok but sometimes when it's running it slows down makes a squeaking noise then speeds back up and continues to dry. It doesn't always do this
    Scholar:
  • 45 Answers
You are having a problem with the drum bearing.
Since you didn't post the model number I cannot tell you if it is a wheel type bearing at the rear of the drum, or a front bushing type bearing, but it is easy to fix either type.
Unplug the power then First remove the upper cover by prying up on the front seam which separates the cover and cabinet. There are two clips there which must be pushed in by a putty knife. If your filter is on the upper cover, remove the filter and then the two small sheet metal screws which secure the filter duct to the upper cover. Then tilt the cover all the way up on the hinges at the rear.
Next remove the front cover of the dryer. There should be two sheet metal screws accessable from inside the cabinet near the top and screweing directly into the front cover. Unplug the leads to the door switch, then tilt the top of the door slightly out and lift up from the lower clips. There may be more screws at the bottom on older models. The drum will tild dow slightly at the front, but don't panic. Place a soda can under it to support it while you inspect.
If you see two rubber wheels at the rear of the cabinet supporting the bottom of the drum, then you will need to remove the drum, clean and inspect. If There are no wheels at the rear of the cabinet then the "bearing" is the top of a circular plastic moulding which is mounted to the interior of the front panel. It will probably be worn down with some parts mission. Buy another and replace it. Before assembling, lubriicate it and the Drum cushion which rides on it liberally with silicone drylube.
To access the rear support wheels, remove the drum by first reaching under the drum and pushing up on the tensioner roller and removing the belt from the pully on the end of the drive motor. You can then lift out the entire drum. Inspect the wheels to see if they spin smoothly on good bearing surfaces. The one on the right usually fails first since it bears the most weight. Buy a replacement on ebay. Ususlly the shaft remains good. polish it up with some wet-or-dry-paper, lube with silicone grease and reassemble.
Take the time to thouroughly vacuum out the entire cabinet assembly and heater coil, blower motor etc. Lint is the worst enemy of dryers and it usually comes from a bad lint filter or a bad/loose exhaust connection. If you want to be extra clean and effficient, remove the rear civer of the dryer and the rear blower cover. It is in line with the motor shaft from the cabinet and to the left as you look at it from the rear. ther are 4 scres which secure it. This will reveal the blower fan. Scum/lint accumulate on the blower vanes and the blower cover which you just removed. Compressed air does the job well, but I know some persons who use a pressure washer to clean everything in one stroke, being careful not to clean off the foam seals. Let dry.
Reassemble and it should work well
Posted on Jun 28, 2009
The ge profile dryer #dpsr473ew is malfunctioning. it makes a very loud squeaking noise when it is on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 31, 2011 | GE Profile DPSR473EW Dryer
My ge profile dpsf495ew dryer is make a squeaking noise
It's the drum bearing . It's in the back of the drum but it can only be accessed from the front. It's regular wear and tear that causes this usually. It's a pretty tough job for someone that has not done it before.
Jul 01, 2010 | GE Profile DPSF495EW Dryer
My harmony dryer makes a very loud vibrating noise and does not heat sometimes
heatman101
trsyw
Jan 21, 2010 | GE Profile Harmony DPGT750EC Electric...
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Dpsr475gw0ww GE Profile Gas Dryer noisy
The felt seal should be replaced if it is bunching up. The squeak could be due to worn drum rollers in the rear.
Jan 07, 2018 | GE Profile DPSR475GW Dryer
Gas dryer makes loud noise when first started. noise level goes down after running several minutes
heatman101
fghgs
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
Loud dryer noise
heatman101
sfhgf
GE Profile Harmony DPGT750EC Electric Dryer Logo
155 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
