Question about KitchenAid KSCS25IN Side by Side Refrigerator
What is the correct temp on my side by side kitchen aide refrigerator
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
SOURCE: Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
Posted on May 26, 2008
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Posted on Jul 05, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
tborn6
  • 700 Answers
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
My freezer is too cold
There should be a freezer and a fridge side temperature setting , look for both is fridge side
Oct 05, 2014 | KitchenAid Kitchen Aid - KSC23C8EYY...
I have a Kitchen Aid side by side refrigerator, My ice maker seems to be leaking. The ice cubes are hollow and there is ice down the side of the door.
Your filter is due to be replaced, not enough water is getting in. Also check the temp setting and blockage from air duct will not allow freezing.
Oct 11, 2010 | KitchenAid KSRB25FKSS Side by Side...
My kitchen aid refrigerator is not cooling like it use to, the freezer side is ice cold but the fridge side is almost at room temp, i have a feeling its the thingy in between the freezer and fridge at the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | KitchenAid KSRS25IL Side by Side...
Freezer won't shut itself off
turn the temp up a bit and see if it shuts off if not it needs to be repaired,hope this helps ya
Cheers
Johnthetr870
May 15, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Mar 19, 2009 | KitchenAid Refrigerators
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Older hobart kitchen aide Supera by hobart KDH7A
If i remember correctly, a KD7 was built in the 70's or early 80's, we used to service them before being sold to Inglis. Seeing it uses the same water solenoids to fill, and asuming it is filling ok, I would suspect worn arms and hubs. If it doesn't fill completely, the fill valve coils may be opening when they get hot from the water flow. The fact that you need a new rack would indicate wear thhoughout and may be too old to justify repair. Find your local Inglis dealer to check on parts availability.
Nov 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KSCS25IN Side by Side Refrigerator Logo
19 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
