Question about Dryers
Not heating kenmore dryer model 970-c81062-10
  • 177 Answers
SOURCE: Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
Posted on May 08, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
  • 1028 Answers
SOURCE: how to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Posted on Jul 05, 2008
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Kenmore dryer model 970-C85092-00 no heat
element or stats........cheers
Apr 15, 2014 | Dryers
I have a Kenmore Dryer (Model 970-C87022-00), there is heat, however it does not dry the clothes. They actually feel wetter.
The most typical reason a dryer will heat yet not dry the clothes is going a blocked.restricted or crushed vent. Check the venting from the back of the dryer all the way outside and make sure its blowing good air pressure all the way through it,Also check inside of the dryer at the housing where the blower wheel is for lint build up.
GENE
Sep 18, 2011 | Dryers
I have kenmore washer/dryer combo model 970-C98802-00. Been using for years until last week it starts tripping the breaker when using the dryer. It does not trip the breaker if no heat. It only trips the...
since it runs on air you have a grounded heater coil. Either the heater has sagged or broken and is touching the frame, here is a website that will assist you, Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 31, 2011 | Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
No Heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Mar 07, 2009 | Kenmore Dryers
May 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
21 people viewed this question
Top Dryers Experts
