Question about Kitchen Appliances - Others
Appliance does not work
When motion sensors are covered, manually or by cat, the rakecycle does not turn on.
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
Change battery ws4904p
First, make sure you have the correct replacement battery. Go ahead and get a Lithium CR123A battery. These are rather expensive at retail, so do yourself a favor and get as many as you need at an online source such as Amazon. These sensors require one battery. The DSC glass break sensors in our home required two. Our glass break sensor went out within a week of the motion sensor, so I just replaced all of them. YMMV.
Second, determine which way the sensor is housed in the, uh, housing. The "bottom" will have a small tab with a circle in the middle, like the picture below.
As you can see from my incredimazing MS Paint skillz, use your knuckles to gently tap the sensor away from the tab. It should pop right off. This can be annoying if you don't have lightning speed and cat-like reflexes to prevent it from falling behind the entertainment center.
Once the sensor is removed from the housing, push the battery cover off of the battery compartment. Remove the old battery, and install the replacement in the same direction. Put the cover back on, and then align the sensor in the housing until it is flush with the bottom part of the housing. Remember to recycle the old battery if at all possible. Good luck!
Sep 12, 2013 | DSC Ws4904p Wireless Motion Detector...
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
I have a cooper 6107 motion sensing 3 way wall swithch and I am using it to replace a three way non motion sensing switch. I have it wired correctly, green to ground, black to common, and the red and brown...
Cooper 6107 instruction sheets:
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/instruction_sheets/469mt_pta_rev._a_.pdf
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/spec_sheets/std_sensswitch_spsht_4_10_anp.pdf
3-way installation shows two motion sensor switches.
Instructions do not show 1 motion sensor and 1 ordinary 3-way switch.
Also note the maximum load rating is 500Watt
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical work or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Cooper Wiring Devices Motion Sensing...
Hello, I have a Sportline Digital Motion Sensor.
Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
Make sure the battery is inserted with the positivet side up?
Manual is here: http://www.sportline.com/manuals/370.pdf
Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
I installed the motion sensor on a 3way switch. Connected the red lead to the common and the yellow w/red strip lead to a traveler and the black lead to the other traveler. No matter how i switch the...
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Nov 23, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
When i flip the switch on the light stays all night it doesnt turn off it was working fine i dont know what happen an i lost manual so can u please help me
Clean the light motion sesor plate under the light bulb.It dirty and it cover with dirts and moister probally that,why it on all the times.
Oct 16, 2010 | Heath Zenith 270 Degree Replacement Motion...
My car alarm goes off intermittently
Assuming that you have the dealer installed PRESTIGE alarm unit,I would recommend decreasing the sensitivity of the motion sensor, or replacing the alarm control unit. This black plastic piece, located somewhere in the left kicker panel not only handles the sound/motion alarm, but the flashing alarm, the keyless power locks and the theft code for the radio. It is rare that these boxes fail, more than likely a rusty sensor at the doors, trunk or hood will be the culprit. Mine goes off when cats go under the car, and cant figure why. I am making a decision on fixing the alarm, or fixing the cats.
Sep 04, 2010 | 1998 Honda Accord
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
