Question about Sewing Machines
Stitching wants to gather. Tried making stitches shorter and longer still gathers
    Sergeant:
  • Sewing Machines Expert
  • 455 Answers
Sounds like machine is not threaded correctly or need upper tension adjusted. These adjustments can be shown to you by a repair tech.
May have something stuck in Bobbin case tensioner?
Cheers,
Kelly
San Diego, CA
Posted on Jun 16, 2014
2 Suggested Answers
  • 1564 Answers
SOURCE: Stitching keeps gathering while I'm sewing
#1 cause of puckering is a tension/threading problem. Make sure the thread/needle matches the fabric type too.
Posted on Dec 15, 2012
Straight stitching is pulling and gathering how can I fix this
there is a few things I know of that can cause this !
one is if supply thread tension is too great , this can be caused by spring tension knob misadjusted or broken
thread not routed properly
needle is bent ,
last but not least using some candle wax to lube base plate it sure helps to keep thigns from sticking
Oct 04, 2016 | Sewing Machines
Could not sew buttonhole . The tread gathered in one spot and wouldn't move further
Hard to assist without a make/model.
If it has a built-in buttonhole function, you may need to take it for service.
If it is a function you have to do manually, then you probably need to set the stitch length a little longer. A shorter stitch length will cause the needle to stitch on top of the previous stitch causing a big knot of thread.
May 06, 2016 | Sewing Machines
Can you gather
You can always gather on a sewing machine, no matter its age or model.
Usually, I like to set the upper tension looser so the upper thread shows on the bottom of the fabric. Set the straight stitch length to very long. Stitch two lines of stitching about 1/4" apart on the fabric.
how to gather fabric
How to Gather basic sewing tutorial
How to Gather Fabric Sewing Machine
Apr 29, 2016 | Sewing Machines
What to set the machine on for gathering
Set the stitch length to the maximum, ie 4 or higher depending on your machine. The other important thing is to loosen the upper tension as far as it will go, ie 0 or whatever. Sew with a straight stitch and sew two parallel lines of stitching about 1/2" to 1" apart.
There are other ways of gathering, but this is usually the first one taught.
Dec 24, 2015 | Sewing Machines
How do I get a good running stitch?
Not specific to your machine - a secret to easier gathering is to drop the tension on the upper thread by 1 or 2 numbers before sewing that gathering line. Then, you pull the bobbin thread when you gather. It will gather MUCH easier. Just don't forget to put the tension back to normal before you start regular sewing again! Temporarily switch to another color bobbin if you're afraid you might forget which is which - you'll be pulling it out anyway. I think most people gather with a stitch that is just .5 mm longer than they're using for construction.
Mar 24, 2015 | Janome Harmony 2041
Having a problem with stitch tension can you help
is it just the fabric that is gathering or the bobbin thread also ?
Jan 24, 2015 | Janome Memory Craft 9000 Computerized...
There doesn't seem to be a stitch long enough on machine for basteing so I can gather material?
Try loosening both top and bottom tension. while longer stitches are easier, it can be done on shorter stitches as well. A bennifit to shorter stitches is the gathers will be smaller and easier to work with! Remember to reset the bobbin tension before sewing again.
Dec 16, 2012 | Janome 8080 Computerized Sewing Machine
Dec 14, 2012 | Singer 3116 Simple
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love www.patternreview.com, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
Stitches are gathering on backside when sewing on patches
This is caused by a bent needle. Try a different needle that is straight. When they get the slightest bed in them the stitching will end on the back side only
Apr 14, 2010 | Brother LS2020 Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
