Question about LG LMV2053 Microwave Oven
LG microwavw won't turn on
I have no power in my microwave after a muffin burned inside by setting too long. Any way to fix this?
  • darryl Apr 22, 2014
    most probably your thermal fuse has blown
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
I agree, most likely the fuse.
Posted on Apr 24, 2014
2 Suggested Answers
  • 183 Answers
SOURCE: LG LMVM2055SW won't turn on
Its fried the machine time to buy a new one sorry
Posted on Jul 27, 2010
My lg microwavwe wont stop running but doesnt heat.when you press it says door
You may have either a defective door switch, or the latch assembly is not properly activating the switches.
Jan 26, 2017 | Microwave Ovens
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
My daughter's GE Model JVM2070SK02 failed to shut off this morning which ignited a muffin that was in the microwave. She stated that she had been having problems with it that that required unplugging the...
It sounds like a cook relay stuck closed and this is why it continued to cook. When the door was opened it should have blown the monitor fuse (which is how it is designed to for safety) so that it cannot cook when the door is open. Or, a cavity temp fuse was blown due to the fire inside. Also a safety feature.
Oct 08, 2013 | GE Profile Spacemaker Over-the-Range...
How many watts hot point microwavw m#rvm1435wd001
Your RVM1435 microwave is rated at 950 Watts for cooking. Total watts will be slightly higher as the power used for the display, clock, etc. are not counted for cook power. Here are the rest of the common specifications.
I hope this helps - please rate my reply. Thanks.
May 20, 2011 | Microwave Ovens
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
LG LMV2053 Microwave Oven Logo
59 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
