SOURCE: Culligan ac 30 reverse osmosis system - changed
I would pull out all the filters changed and check them. If a GAC filter is used as the post filter, before the RO tank, carbon fines can come out of the filter and can plug up the head on the RO system. Make sure the sediment pre-filter is not plugged and there is plenty of water supply. You may have lost pressure in the RO tank. A 3 gallon tank should have 7psi pressure when totally empty.
RJ
SOURCE: how to replace filter
Turn off the incoming water supply, turn off the valve on storage tank, open the RO faucet and let pressure off. Have a pan ready, remove the sediment pre-filter housing and post-carbon housing.
Use latex gloves when changing filters, add 1 tsp bleach to each housing and clean them thoroughly before installing filters. Make sure all bleach is rinsed out before installing filters. Turn the water back on to system, turn the tank back on and run 2 tanks of water out before using water again.
RJ
SOURCE: I have a Culligan AC
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
SOURCE: Culligan AC-30 osmosis water system housing leak
Depending on which type of plastic you have, it should say on it somewhere and it should look like a triangle and it will tell u pvc or nilon or abc. Then go get that type of glue and seal it with the correct glue. You could also use a food grade silicone, but remember to rough it up with some sand paper.
