Question about Frontgate Nespresso Pixie Brown Machine - Yellow - Frontgate
No water, no coffee coming through machine
On our first try with the Nespresso Pixie, it makes noise, but no water is pumped through the machine.
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I want to know if my Nespresso Pixie D60 has a fuse protection because i plugged my 120 volt 60hz machine into a 220 volt 50 hz power supply without a converter.has my nespresso completely burnt and r
There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
Posted on Sep 23, 2012
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
My machine both Expresso and Lungo lights keep flash, how do I fix it?
Expresso is not coffee. Espresso is. So I assume you don't have a real coffee machine...
Jan 01, 2015 | Nespresso Pixie C60 Espresso Machine -...
How do I repair a Teflon tube on NESPRESSO Pixie COFFE MACHINE
You purchase the correct tube as a spare part from a supplier. Give your model to Nespresso and ask for direction.
Dec 20, 2014 | Frontgate Nespresso Pixie Brown Machine -...
Nespresso pixie c60 only brews for a few seconds on full cup mode
Would love more info, like how long did you have this item and did it go from 10 seconds to 3 seconds with less water over a period of time or just over night?
if this has been giving you less and less water and taking / shorting the amount of time you might have Calcium build up inside the unit that is not that easy to clean out, Seen it happen on a mr coffee unit it would make a 1/2 pot of coffee because of the build up from the hard water in the area.. Needed a new coffee maker.
Dec 09, 2014 | Nespresso Pixie C60 Espresso Maker...
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
Frontgate Nespresso Pixie Brown Machine - Yellow - Frontgate Logo
14 people viewed this question
Top Frontgate Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Frontgate Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
