Question about Kenmore 20022 3.4 cu. ft. Top-Load Washer
Clicking noise Before it goes into the rinse cycle and spin cycle, I hear click click click click then it waits, clicks more then there's a sudden whirl noise (as if something finally caught) and then it will go into the spins. It never clicked before
jsrock516
  • 5911 Answers
SOURCE: Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Posted on Apr 29, 2007
dutchman05
  • 487 Answers
SOURCE: Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Posted on Apr 22, 2008
Lumpy816
  • 246 Answers
SOURCE: kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: Kenmore elite clicking noise
This may sound basic and I'm not trying to be a wise guy, but is there any metal objects in the washer, like a pair of jeans with metal buttons? This could be the clicking that you hear.
Posted on Oct 16, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 90 series - clicking during slugish spinning cycle
try your unit on a outlet by it self ,,nothing can be on this line,,sounds like weak ampage,,this machine needs 15 amps line by it self...
Posted on Dec 28, 2008
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
No spin cycle
dear zoofan.lets see hum.....to agaitate the motor goes one direction.to spin useing the same belt it goes the oposing direction.so when spins lid switch completes curcit to motor then it would spin so if click you hear is the motor protector switch [its like a curcit breaker] kicksout that means you lid switch is working. but could the noise be the timer advancing? timer makes clicking noieses also.then that would put into question your lid switch.but you said it starts again after a few minutes.if thats a sure thing then it ,your motor is involved but a possiable is somthing is between the tubs[thats a visiual inspection]sock,any clothing or if had a nail or somthing of that sort going thru small holes in inner tub then jaming or draging on the outer tub that could stop the tub but most of the time the motor would go and would burn the belt.hope i gave you a few clues,God bless ,tom
Jan 06, 2009 | Frigidaire FWS445RF
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Roper 7 cycle
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch part number3949247
Mar 04, 2008 | Washing Machines
Kenmore 20022 3.4 cu. ft. Top-Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
