Question about GE 30 in. Profile JP350 Electric Cooktop
How do i repair loose control knob on GE radiant cooktop model jp350
  • 4 Answers
SOURCE: GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Posted on Jan 20, 2008
Eddie Rentas
  • 59 Answers
SOURCE: ge jp340 radiant cooktop
Hello
I have the manual for your stove in PDF format, I will gladly email it to you.
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Posted on Mar 02, 2009
  • 116 Answers
SOURCE: I have a GE 30
Hi sounds like you have a busted switch assembly, this is very much fixable the part is around $50, but you would need to remove the top of the stove which requires pulling the unit from the counter, this is slightly more involved, but definitely doable i would also change the knob. A more accurate name would be infinite switch.
Sean
Posted on Mar 28, 2011
Daniel S
  • 4323 Answers
SOURCE: GE radiant cooktop model JP350.
Hi
Test the switch for continuity, if it tests open then replace it however, replacing both of them is always a better option. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 19, 2011
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
I have a GE 30 in. Profile JP350 Cooktop. The large, front and right control seems stripped and will no longer control the cooktop. Also, the part that it sits on at the cooktop is not protruding up as...
Sean
Mar 28, 2011 | GE 30 in. Profile JP350 Electric Cooktop
Why is ON light glowing with knobs on off GE PROFILE COOKTOP
That is to tell you that your Infinity Switches are faulty and no good.
So whatever one is lit, change it
Jul 26, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Mar 02, 2009 | GE Cooktops
GE Profile JP350 cooktop stopped working
OK, i think the problem took care of itself. definitely got water down in the infinite switch for the lower right burner. let it dry 12 hours and reset the breaker, now works fine. but, i know if i do that again, or if it happens randomly, i will have to replace the switch and seals (available at repairclinic.com)
to do that, you have to remove the cooktop (screwed down by a strap in the back to the back wall of the cabinet) remove the sheetmetal to access the switches and replace. just keep the wiring straight, and ALWAYS replace the seals, they leak over time.
Nov 09, 2008 | GE 30 in. Profile JP350 Electric Cooktop
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
Circuit Braker Jump Off Easily on GE JP350 Cooktop
The ciruit breaker might not be of sufficient rating. Tell us what is the number written on the breaker?
Oct 27, 2007 | Cooktops
GE 30 in. Profile JP350 Electric Cooktop Logo
98 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
