Question about Fellowes PS60C-2 Shredder
Durabrand shredder model wm6x runs in reverse but not forward
I have a durabrand shredder model wm6x, the motor and blades work in reverse but the motor doesn't even turn on it the forward shredding position. What is the problem and how can I fix it?
  • 328 Answers
Try cleaning the sensors with a cotton swab and alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. easy install.
Posted on Dec 20, 2010
My shredder will not work. It makes sounds both forward and reverse, but the blades don't; turn. There's no jam signal. Help!!
Most likely one of the gears popped off or cracked. The blades are gear driven by a motor and it's pretty straight forward. If the blades aren't moving, then it's probably a gear problem since you said the motor runs.
Not much you can do without taking it apart.
Good luck. =)
Mar 10, 2015 | Shredder Office Equipment & Supplies
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
RE; Durabrand Paper Shredder. Model Number WM6X. The motor works in reverse mode only, but the blades don't turn, Help
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. Easy install.
Nov 05, 2009 | Office Equipment & Supplies
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
May 26, 2009 | Office Equipment & Supplies
Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Mar 13, 2009 | Fellowes OD700C Shredder
I need replacement gears for my Durabrand model WM6X Paper Shrdr?
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 01, 2009 | Office Equipment & Supplies
My Durabrand Shredder, model WM6X,.
Nov 01, 2008 | Office Equipment & Supplies
Motor runs blades not turn
Sorry about that, there is no gears for that machnie. Have a great day!
May 08, 2008 | Fellowes 3011001 Shredder
Fellowes PS60C-2 Shredder Logo
1,058 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
