Question about Waring Pro SDM50 2-Speed Blender
Waring 34bl87 blender assembly stuck - Waring Pro SDM50 2-Speed Blender
  • 3 Answers
SOURCE: Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
SOURCE: Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Posted on Nov 15, 2008
  • 2841 Answers
SOURCE: I broke the jar to
This diagram shows you exactly how to assemble the washers and seals. Click the link to see a list larger photo with parts list. http://www.californiaelectricservice.com/waring_pbb_blender_parts.asp b395502.png
Posted on Oct 08, 2010
  • 394 Answers
SOURCE: i have a waring
Hi I am Steve, lets get you some help.
I assume this is the retaining collar on the blender that you twist to release the top assembly rather than anything else.
It could just be out of alignment and gently shaking the bowl whilst applying a pressure to the collar may clear whatever is causing the jam.
Posted on Feb 06, 2011
vko007us
  • 254 Answers
SOURCE: how to replace a blade assembly on a waring
Hi, plz try this link if it works:
http://www.beveragefactory.com/refrigeration/blenders-juicers/blenders/MBB518.shtml
Posted on Aug 22, 2011
Need picture waring mbb518 blender motor
Go to the following link and locate your blender's model type: http://www.waringcommercialproducts.com/product-documents.php?type=parts
Nov 24, 2013 | Waring MBB518 2Speed Blender
Waring 34BL87 blender is loud and gives off a strong burning smell whenever used. Burning smell apparent since first day of use and getting worse with age. Is this odor normal or does it indicate the...
no, that is not normal. it could be from a loose or misallignment rotor or shafting. if its under warranty you should return it from the store...
Jun 17, 2011 | Waring TG15 Blender
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Dec 28, 2007 | Waring BB180 Work Top Blender
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Waring Pro SDM50 2-Speed Blender Logo
222 people viewed this question
Top Waring Blenders Experts
Darial Jr Lasaria
Darial Jr Lasaria
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
