Question about Electrical Supplies
Garage door push button can't open the garage door
  • 476 Answers
SOURCE: Liftmaster 1280 LMC Motion Detector Garage Opener Push Button Pad Not Working
Have you tried to reprogram the chanel again?
Changed the battery?
Posted on Aug 02, 2008
  • 4 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
  • 25 Answers
SOURCE: Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
Posted on Jun 07, 2009
  • 25 Answers
SOURCE: change code on keypad for model 61WD liftmaster garage door opene
is it little buttons on the remote change the buttons on the back of your operator to the same has the ones inside your remote. or if it's a newer one you can hold the square button of the back of the operator in for 8 secs. then after that you push the button and let go and then push the button on your remote. done
Posted on Jun 11, 2009
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
I just installed a new Genie Silentmax 1000. The wall switch works. The up and down settings are right. The safety doors sensors are working. My problem now is that I can't get the remotes or the key...
On the back of the garage door opener there will be a button that you will push it will start flashing right then you will push the garage door opener button and do the same freaking packed push the button wait for the blinking light enter your code and pushed enter
Feb 16, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
How do i program my garage door to open with my car garage opener button
Push and hold the two outer buttons until the LED flashes fast Approx (15 seconds) then hold your garage opener up to the mirror or visor and push and hold any button 3 or 4 seconds on the opener Now the Home Link is programed. With the car safely away from the closing garage door find and push the garage openers red programming button (on the motor assembly somewhere that gives you about 30 seconds to push your cars home link button so the garage opener learns the button you want to use for that door the other two buttons can be programed for other doors or house light controler gate opener in the same manner
Jan 03, 2012 | 2004 Nissan Maxima
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
