Question about Nordic Track NordicTrack A2550 PRO Treadmill
Belt is loose
The belt slides to the side
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
There are adjustment bolts on the back end of the treadmill. they are on either side. start with belt running about 3mph. tighten the side where the belt is closest. about 1/4 turn. give 15-20 seconds to see adjustment . when it is centered, tighten both bolts evenly until belt is tight.
Posted on Apr 20, 2014
How do I remove the transfer belt from c450 bizhub konica minolta
1st from the front Open the door and removed all Imaging unit start from the black. 2nd from the left side when your facesing the c450 Open remove the waste box. 3rd from there you will see the transfer belt on both side of it you will see screw just under the transfer belt loose it. Slide the transfer belt toward you.
Jan 08, 2015 | Konica Minolta bizhub C450P Laser Printer
Belt is loose around the dryer drum
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
May 19, 2012 | Roper Dryers
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
Carriage belt is off, loose when on
Carriage belts are tensioned inside the machine on one of the idler pulleys. A belt that came off usually indicates there is a lubrication issue - one of the pulleys won't turn easy or the print head is binding on the slide shaft (Extremely common). The belt may have stretched (though unlikely) You may be able buy the belts from SDP-si.com in the US. This is just one of the sources. Try a printer repair shop.
Mar 20, 2010 | Dell 966 All-In-One InkJet Printer
How do you adjust the belt so it does not slide from side to side?
Sounds like the belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Mar 19, 2010 | Exercise & Fitness
My weslo cadence 200 treadmill belt keeps slipping to the left. i keep tightening and loosing it to keep it even but i keeps sliding to the left
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Nov 24, 2009 | Proform XP Weight Loss 620 Treadmill
Works but doesnt spin. Where is the belt located. I think that might be the problem.
To access your drive belt, you need to take the front cover off. Unplug the dryer first.
There should be 2 screws on the front cover in the lower front area. Remove the screws and tip the bottom of the front panel forward until the top clips are frree of the top panel. Be careful there is a door safety switch wired. You can disconnect the wire and set the front panel aside.
Look under the drum in the dryer and you'll be able to tell if the belt is broken or loose.
IF you need to replace it, you'll need to take the 4 screws that hold the front drum support/duct assembly loose from the dryer case. Once these are removed you can pull out the whole gray assembly and slide the drum out.
The new belt can be purchased online at repairclinic.com if you want.
To put back in, you can put the belt around the drum and slide it back in. It should have a grooved side and a flat side on the belt. Put the flat side toward the drum. It routes around the motor pulley and a tensioner pulley. It may take a bit to figure out the routing, but the key is to put the belt into the indentation ring on the drum to allow you to get it around the pulley and tensioner... if you leave the drum sticking out of the machine about 8 inches, you can reach thru the drum and hook the belt in place, then slide the drum in and pull the belt out of the indentation and onto the larger circumference of the drum. You may have to twist the belt to get the flat side next to the drum.
You can then put it all back together...
Good luck... be patient and you can do it.
Sep 10, 2009 | Maytag HYG3460AWW Gas Dryer
How do you open the dryer to fix the belt
First before you you raise the top, open the cover on the back by the motor and let the belt loose from the motor pulley unless the belt has broken. If it has go to the lid. Slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. Three are usually two screws, one on each side holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on.
Jun 06, 2009 | Maytag MDG6000 Dryer
Need directions for changine belt for brushes
There is a door on the side pop it off remove the old belt and simply slide the new belt on. Over the motor shaft first then the roller brush end.
Apr 12, 2009 | Vacuums
When running, belt feels like it gets caught or slides off track.
Mar 11, 2009 | Exercise & Fitness
Nordic Track NordicTrack A2550 PRO Treadmill Logo
106 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
