I am not quiet sure how to delete photos on my samsung camera
SOURCE: camara won t delete photos
Is your memory card locked? It won't let you delete pictures if it is. Check the little switch on the side of the memory card and move it in the opposite direction and then see what happens. Good Luck.
SOURCE: deleting photos
You will need to format the memory. Have a look at the manual for instructions or download from this link. The format instructions are on page 36
http://www.samsungcamera.com/popup/download.asp?prol_uid=2699&prj_uid=590
You will need to allow popups to show this page.
If it works don't forget to 'fixya'!!
SOURCE: retrieving deleted picture on samsung s630 camera
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
SOURCE: retrieve erased photos
There are photo retrieval software programs available for about 30 to 40 dollars. Search the internet for what you want. Just don't take any pics on the card or your original pictures will be overwritten.
SOURCE: I have a Samsung Digital
To delete all the contents off the camera / media card you will need to navigate to the format option in the camera menu. Press menu then settings then format. NOTE this will delete EVERYTHING off the card.
To upload video files to your computer try taking the card out of the camera and connect it to your computers card reader (or buy one if you need) and open up the removable drive in my computer, copy the files you need onto the PC hard drive from the removable drive. You could also use the Intelli-studio software that came with the camera to transfer video files.
Chris
