Question about Sanyo DP50749 50 in. Plasma TV
Sanyo DP-50749 power comes on and goes off - Sanyo DP50749 50 in. Plasma TV
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: DP 42848 Sanyo
It can be the 24vdc power supply problem which supplies the power for the backlights inverter board, or the backlights inverter board is bad, or T-CON board is bad, you need to do this when the screen goes black:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 31, 2011
walesarumi
  • 6993 Answers
SOURCE: Sanyo DP 42647 has no power it won't turn on at
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress from www.shopjimmy.com
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Sep 27, 2011
SOURCE: SANYO DP 50710
Sounds like a bad main board !!!
Posted on Jul 29, 2012
Yes I have a DP 50749 sanyo plasma tv 50 inch the green power led comes on for 20 seconds goes off. then it sounds like relay on the main power board starts a clicking noise Then it stops clicking...
This is likely a heat issue, and the CPU of the tuner is instructing the power board to switch it off for reasons related to over heating. Check that a fan ventilation improves the problem. The solution is not easy but maybe adding a fan to the tuner CPU can fix this issue.
May 07, 2014 | Sanyo DP50749 50 in. Plasma TV
My sanyo dp 55441 wont come on
Try unplugging the TV, an hour later, now reset the TV back to Factory Settings. Now, the TV should be working properly now. Try a website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 13, 2013 | Sanyo DP55441 55 in. LCD HDTV
Hello, i have a sanyo dp 19648 that was working perfectly when last used, i have been away on a trip & turned all electric power right off from the mains & when i got back, the tv will not come on...
Power supply in set has a standby the runs 7/24 (all sets do and computers also) and the loss of power when restored may have damaged something there---a fuse is possible and should be looked at first---the Standby provides voltage for the remote to turn main supply and the set on.
Nov 06, 2012 | Sanyo Televison & Video
SANYO DP 50710
Jul 28, 2012 | Sanyo DP50747 50 in. Plasma TV
No power to my DP 19649 Sanyo TV. Where is reset button? Manual doesn't mention one.
There is no reset button
The hard reset process is to disconnect power for 1 hour then reconnect
Feb 19, 2012 | Televison & Video
I need to set up my tv remote for my new sanyo 50 inch plasma and I threw away my manual by accident. It is model 50749. thank youl.
Here's a link to the manual (I always toss them, too)!
http://us.sanyo.com/dynamic/product/Downloads/DP50749%20OM%20(332--)-45914968.pdf
Hope this helps!
Rate my solution!
Jan 05, 2010 | Sanyo DP42746 42 in. Plasma Television
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Will not come on /nothing happens
you have a power supply problem, i will check the power supply first. maybe it is only a fuse.
May 19, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo main board
Sanyo 1-800-877-5036
Or... www.shopjimmy.com for used parts.
Jul 25, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP50749 50 in. Plasma TV Logo
76 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
