Question about Fuji J150w Digital Camera
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please help..........dont want to buy another camera.
  • 244 Answers
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Posted on Jun 20, 2009
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
Nikon j1 flash not working
Does the flash ready indicator also stay off, after you opened the flash and pressed the shutter release button half?
Because that could indicate there is not enough power in the battery to charge the flash.
If the light comes on, and still the flash does not fire, there would be a serious problem. My guess; that only can be solved at the service centre.
To be sure nothing else is wrong. Charge the battery first.
Then switch on the camera, open the flash, select fill in flash and press the shutter release button half. If the flash ready indicator lights, press the shutter complete and see if it works.
Succes
Jan 13, 2014 | Nikon 1 J1 10.1MP HD Digital Camera With...
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
I am not able to shoot with my canon 350d using the shutter release or the clicking button. All that is happening is that when I switch on, it just keeps shooting and when I try to use the shutter release...
Remove the battery and memory card, press and hold power for 60 seconds to remove residual voltage and reset the processor, if there is no change a camera repair shop is the next stage for assessment.
Jul 08, 2012 | Canon Rebel XT / EOS 350D Digital Camera
When i press the shutter button to take a photo the shutter goes up and the power goes down. i have to remove the battery (sometimes wait a few seconds) reinsert it and then the shutter closes. It does not...
If your camera battery is having limited current factor, there is a possibility that the entire action is not happening with the available voltage/current. as multimeter test of voltage might indicate the voltage but the current factor will need a series test. hence I advice you replace the batery and test again. If the fault recurrs then the camera electronics is at fault, possible that the shutter mechansim is taking up power and stenching the cirrcuits to hang up. I feel the camera has to be open out to confirm the power hang.hope I could help.? Good day
Jun 25, 2010 | Cameras
The shutter on my canon a-1 seems to be stuck. After I wind up the film, nothing happens after I press the shutter button. I opened the bottom of the camera up and pressed the L-shaped lever and magnet to...
If you opened the bottom you saw the magnet that holds the shutter /mirror mechanism closed- sometimes it and the lever it holds get dirt or corrosion on them and won't hold the lever when you **** the shutter? it can also be the battery is not dead, but not enough voltage to supply enough power to hold lever.
Aug 24, 2009 | Canon Photography
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Jun 01, 2006 | Nikon COOLPIX Cameras
Fuji J150w Digital Camera Logo
122 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
