Question about ASUS 32GB Google Nexus 7" Tablet with Wi-Fi
Nexus 7 charging problems - ASUS 32GB Google Nexus 7" Tablet with Wi-Fi
The battery in my Nexus 7 will not charge. how do i replace it.
you really cant change the battery but if you feel brave you can try to open the nexus up
HOWTO Remove and Replace Nexus 7 Battery
Dec 19, 2014 | Google Nexus 7
How do I fix my nexus 7 charging port
If the port is broken and you only need it for charging the device, consider getting a wireless charging accessory instead:
Finally charging for our multi device world
Jul 13, 2014 | Google Nexus 7
Nexus 7 tablet flashing white light
I am very familiar with this problem with the 2nd gens and it is almost always a sure sign that the tablet is not getting enough power to charge up and will not boot. Sometimes this can happen from the tablet not getting used for a while and getting completely drained. The other possibilities are A) the USB charging port is becoming worn out and won't charge or B) the battery is no longer holding a charge, much like a car battery in the winter. Get an original Nexus 7 wall charger and leave it charging through the wall outlet and not a computer, this has more power. If the light is blinking, it makes me think the USB is not the issue, so chances are after an hour or two it will have some life again.
Jun 14, 2014 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet fails to turn on.
Plug it in to give it a full charge. Push the on/off button and hold it in until it turns on. It may take about a minute. I had the same problem with my Nexus 7 because I let the battery get too low and it would not turn on.
Jan 17, 2014 | Nexus Tablets & eReaders
Nexus 7 wont turn on for longer than a second, then it says powering off.
Charge your nexus using the ASUS wall charger that came with your nexus.
Once you connect your Nexus to the wall, just push the power button once (do not hold). A battery animation should appear showing that the tablet is charging. Let it sit for a while, then power it up.
If you suspect it's a hardware problem and if you feel comfortable opening up your device, please let me know so I can give you a step by step walk through to figure out what exactly is going on with your device.
Apr 06, 2013 | Google Nexus 7
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Charging problem google nexus 7
i have a problem with my nexus7 and it want charge or turn on please help me with this problem
Jan 16, 2013 | ASUS 32GB Google Nexus 7" Tablet with...
ASUS 32GB Google Nexus 7" Tablet with Wi-Fi Logo
24 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
