Question about Troy-Bilt 32cc 4Cycle Backpack Blower
Fuel lines desengrated need to no how to reroute
1981 Yamaha XJ650 engine not getting fuel
Hi, Terry always check the fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve/petcock not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Carburetor Issues on my 1982 xj650
Total Motorcycle Forums
Yamaha XJ750 Owner Manual service manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 24, 2017 | 1981 Yamaha XJ 650
Can't seem to get fuel delivery from fuel tank to inlet valve
Hi, Richard always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing*
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn*
8. Fuel pump not working*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Gas Tank Question
How to Diagnose Motorcycle Fuel System Problems
Nov 04, 2016 | Motorcycles
Wont fire up after its been running a whlie
May have a vapor lock in the fuel line. Rerouting the line may help. If you are in a jam, try putting ice on the fuel lines, I know, it's gonna be tough but it will solve a vapor lock.
Mar 24, 2014 | 1999 kawasaki ZX-7R
2003 Kawasaki KX 125 carburetor not getting fuel
Hi, Anonymous you need to locate the fuel flow origin first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
4. Fuel valve not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing.
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn.
8. Fuel pump not working.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KX 125 won start have tried everything
What to Do Check When Dirt Bike Won Start
Kawasaki KX125 Service Manual
OEM Parts for Kawasaki
2003 Kawasaki KX125 Owner Manual
Jan 06, 2014 | 2003 kawasaki KX 125
1995 Kawasaki VN 800 A Vulcan not getting gas to the carburetor
1. Fuel tank empty.
not getting fuel
2000 Vulcan 800 Carburetor not getting fuel
KAWASAKI VN800 Service Manual
1995 Kawasaki Vulcan 800 Owner Manual
Oct 14, 2012 | 1995 kawasaki VN 800 A Vulcan
2001 Suzuki GSX 750 F (Katana) carburetors not getting fuel
Hi, Larae always check the fuel flow origin first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
ISSUE engine not getting fuel Suzuki GSX Motorcycle Forums Gixxer com
Fuel supply valve on Suzuki GSX750F Katana
Suzuki 85 GSX R750 Service Repair Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Oct 30, 2017 | 2001 Suzuki GSX 750 F (Katana)
My cpi gtr 50 won't take in fuel i've cleaned the carb n the fuel but nott'n happens line
Hi, Kaleovidinha always check the fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Fuel and Vac Line Tutorial
scooter not getting gas
CPI GTR 50 Service Manual
CPI Scooter Parts Racing Planet USA
CPI GTR 50 2009
Aug 27, 2011 | 2009 Cpi GTR 50
When I'm riding, the bike starts to studder and ****, when the temperature gage reading is above 205 degrees.It wants to stall out like its not getting gas.
Sounds like a fuel vapor lock problem. The gas is trying to boil in the lines and it creates a vapor. Check your fuel line routing, reroute and insulate as needed.I hope this helps.
Jul 03, 2011 | 2002 Suzuki GSX 750
Troy-Bilt 32cc 4Cycle Backpack Blower Logo
54 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
