Question about Specialized Crossroads
Grease wheel hubs
Balls have no race and fallout
  • 4 Answers
The race is actually threaded onto onto the axle it is best to only loosen the axle enough to add grease then tighten it back up. It is typical to use grease to make them sticky enough that you can get them back in place with out losing any.
P.S. if you do lose some then take a picture of your bike with you phone and put the remaining bearings in a clear baggy ands take these two item to your local bike shop. They will probably have some and may not even charge you for what you need. YOU HAVE TO TAKE YOU BEARINGS TO THEM SO THEY CAN MATCH THE SIZE.
Posted on Jul 15, 2014
Replace front hub assembly 2002 Suzuki XL7
the front wheel bearing hub?
XL-7 (the dash matters)
my wild guess, is the questions was
what are all steps to do this job. and tools.
that?
RTM?
https://suzukipitstopplus.com/Products/10056-2002-grand-vitara-xl-7-service-manual.aspx
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
the link shows all years, and variances.
here is a photo review, that is accurate up to
1998, and beyond , if you skip the bearing service parts. as yours are INTEGRATED
and NON-serviceable.
the photo 6a and B
shows removing the hub,
so do that , buy a new hub and put it back
the same way, using the tool stated
at the stated ranges of torque
123-180 ft/lbs.
this range allows you to get the screws into the locking rings.
Dec 11, 2016 | 2002 Suzuki XL-7
How to replace right front wheel bearings
What you'll need:
  1. Large adjustable wrench and Channelocks.
  2. Bearing race driver tool or various size punches.
  3. Socket and ratchet set or assorted wrenches.
  4. BFH.
  5. Lots of rags.
  6. New wheel bearings.
  7. Wheel bearing grease.
  8. New cotter pin.
  9. New grease seals.
  10. Wheel blocks.
  11. Safety glasses.
  12. A jack and a pair of jack stands.
  13. Rubber gloves (Optional)
  1. First remove the bearing cap. This is a press fit and to remove it grab it with your Channelocks and work it back and forth until it pops off. Be careful not to crush it as you remove it.
  2. Once the cap is off you will see a cotter pin, Remove the cotter pin and remove the retainer ring. If your vehicle has a castellated nut, you will not have a retaining ring.
  3. Using your Channelocks or adjustable wrench, remove the nut from the spindle.
  4. Now remove the outer wheel bearing and washer and lay it aside.
  5. Slide the rotor or drum off the spindle. This may be difficult, but it will come off. Don't worry about hurting the grease seal; we're going to replace it anyway.
  6. Now that the rotor or drum is off, use a suitable tool to remove the grease seal and take out the inner wheel bearing.
  7. Using some of the rags wipe all the old grease from inside the hub.
  8. Now we need to remove the bearing races from the hub. Take a punch with a flat narrow tip and place it on the back of the race. Most hubs have gaps in them to expose the back of the race to make removal easier. Tap the race out, alternating from side to side so it comes out evenly and doesn't get cocked in the hub. Once it's out, flip the rotor or drum over and do the same for the other race.
When both races are out, clean the inside of the hub with some rags. Also make sure the spindle is clean as well. You can even use some carburetor cleaner to do a really good job of cleaning. From this point on cleanliness is important. You do not want any dirt, sand or metal chips inside the hub.
  1. Take one of the new races and coat the outside with some wheel bearing grease. This will help it slide into the hub. If you have a race driver, select the proper size and tap the new race into the hub. Make sure you drive it in evenly and do not **** it. If you don't have a race driver, use your hammer to tap the outside of the race to get it started making sure you tap evenly around the race. When it is flush with the hub, use your flat narrow punch and drive it in the rest of the way. Make sure it is fully seated. The sound of the tapping will change when it's seated and you can look from the other side to visually confirm this.
  2. Do the same for the other race.
  3. If you don't have a bearing packer, you will need to pack them by hand. Put a glob of wheel bearing grease in the palm of your hand. Slip the wheel bearing on your index finger like a ring with the wide end facing out. Then tap the bearing into the glob of grease until you see it coming out the other side. When you see it come out turn the whole bearing, don't just rotate it on your finger, and repeat the procedure until the whole bearing has grease coming out the other side. Repeat this for the other bearings.
Now that everything is nice and clean, let's put the new races and bearings in.
  1. Now that we have the races installed and bearings packed, we can put everything back together. Starting with the inner bearing put a bed of grease on the surface of the race and then push the inner wheel bearing into it. Take the new grease seal and tap it into place, don't bend or distort it. You can use a small block of wood to help.
  2. Put a coating of grease inside the hub between the two races and on the spindle -- too much is better than too little. If any moisture should happen to get inside, the grease will keep the metal from rusting.
  3. Slide the brake rotor or drum straight onto the spindle. It should slide on easily. If it doesn't, the bearing is cocked a little. Slide it off and make sure the bearing is sitting flat and try again.
  4. Once it's on, grease the outer race and slide the outer wheel bearing on. Slide the washer on. The washer will probably have a tab that will align with the spindle, make sure that you line them up when you put it in.
  5. Place the nut on the spindle and tighten it by hand until it won't go anymore. Spin the rotor or drum a few times back and forth and then tighten the nut more by hand. This insures that the bearings are seated. Do it a couple of times until you can't get it any tighter by hand.
  6. Now tighten the nut ΒΌ turn, no more than 16 foot-pounds. If you have a castellated nut, line it up with the hole going through the spindle. Install a NEW cotter pin. If you have a retaining ring, place it on the nut and install the pin. Never reuse the old cotter pin and make sure you use it.
  7. Put a small blob of grease on the inside of the dust cap and tap it into place, being careful not to crush it. Make sure it is fully seated.That's it, you're ready to roll nice and smooth!
May 06, 2011 | Geo Storm Cars & Trucks
The bike is circa 1982, ten speed, and the chain stopped rolling as I coasted. I took the rear tire off and removed all the stuff down to the cassett and lots of 1/4 and more 1/16 balls and washers and...
Hi, before the loose bearings are installed you need to insert the shaft through the wheel hub. Then, apply some thick grease to the bearing race, (that's the curved part where the bearings ride). With the grease in place you can "stick" the bearings onto the race one by one. Then, thread the opposing race to that side and hold it in place to repeat the procedure on the other side of the hub. Hope that helps!
Nov 15, 2010 | Ross Cycling
How to change fornt drivers wheel bearing on grand vitara 2002 model 2.0 ltr 5 door and where can i get a repair manual for this model
REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Brake caliper and rotor
    • Locking hub or hub drive flange, if equipped
    • Hub grease cap, if equipped
    • Wheel speed sensor, if equipped
    • Wheel bearing lockwasher
    • Wheel bearing locknut and inner washer
    • Wheel hub and bearing assembly
    • Wheel hub oil seal
    • Wheel bearing oil seal
    • Snapring
  3. Press the wheel bearing and race out of the hub. To install:
  4. Press the wheel bearing and race into the hub so that the race is fully seated in the hub bore.
  5. Install or connect the following:
    • Snapring
    • Wheel bearing locknut and inner washer. Tighten the nut to 157 ft. lbs. (216 Nm).
    • Wheel bearing lockwasher. Tighten the retaining screws to 13 inch lbs. (1.5 Nm).
    • Front wheel
prev.gif next.gif --- Go to your local auto parts store or library to get a copy of the repair manual for this model.
Aug 26, 2010 | 2002 Suzuki Grand Vitara
What is needed to remedy right hand front wheel bearing play on a 1990 d21 4X4 ute
replace the bearing or wheel hub assembly.
REMOVAL & INSTALLATION 2wd Models NOTE: Refer to wheel bearing service and bearing preload adjustment procedures found in Section 1.
  1. Raise the front of the truck and support it with safety stands. Remove the wheels.
  2. Remove the brake caliper and suspend it with wire, out of the way. Remove the caliper torque plate if equipped.
  3. Remove the dust cap and then remove the cotter pin, lock washer (if equipped) nut lock and nut.
  4. Pull the hub/disc assembly off the spindle with the outer bearing. Don't let the bearing fall out.
  5. Pry the inner oil seal out and remove the inner bearing. To install:
  6. Clean and inspect the bearings and outer races.
  7. Using a brass drift and a hammer, drive out the bearing outer race. Press a new one into position.
  8. Pack the bearings with grease until it oozes out the other side. Coat the inside of the hub and cap with grease.
  9. Position the inner bearing into the hub, coat the oil seal with grease and press it into the hub.
  10. Press the hub assembly onto the spindle and install the outer bearing and thrust washer.
  11. Install the hub nut. Turn the hub a few times to seat the bearings and then loosen the nut until there is 0mm axial play. Using a spring tension gauge, check that the preload (with new grease seal installed) is 2.2–6.4 lbs. (9.8–28.4N)
  12. Install the lock-nut, new cotter pin and hub grease cap.
  13. Install the brake torque plate. Install the brake caliper.
  14. Install the wheels and lower the truck.
4wd Models The hub and bearing service procedures for a 4wd models are basically the same as those for a 2wd version, with the exception of removing the free running hub assembly and the bearing preload adjustment. Refer to Sections 1 and 7 for additional information. Adjust the preload after the wheel bearing is replaced or the front axle assembly is reassembled. BEARING PRELOAD ADJUSTMENT
  1. Thoroughly clean all parts and pack the wheel bearings.
  2. Apply grease to threaded portions of the spindle, grease seal lip and wheel hub.
  3. Tighten the wheel bearing lock-nut with a socket and torque wrench to 58–72 ft. lbs. (78–98 Nm).
  4. Rotate the hub in both directions a few times to seat the bearings. Loosen wheel bearing lock-nut.
  5. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm).
  6. Turn wheel hub several times in both directions.
  7. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm). Fig. 1: Exploded view of the front axle assembly — 2wd models 86718030.gif
    Fig. 2: Removing the bearing outer races 86718032.gif
    Fig. 3: Packing the wheel bearing with grease 86718033.gif
    Fig. 4: Pack the lip cavity of grease seal with grease 86718034.gif
    Fig. 5: Exploded view of the front axle assembly — 4wd models 86718031.gif
  8. Measure wheel bearing axial end-play. The wheel bearing end-play specification is 0.
  9. Install lock washer by tightening the lock-nut within 15–30 degrees.
  10. Turn wheel hub several times in both directions. Wheel bearing should be seated correctly.
  11. If necessary, measure wheel bearing preload. NOTE: Measure wheel bearing preload with a spring-type gauge; measure at wheel hub bolt, with tire removed. The hub assembly should rotate with 1.6–4.7 lbs. (0.73–2.13 kg) of pressure.
Jul 28, 2010 | 1991 Nissan Pickup
How do u change the rear bearings?
Hello Friend:
#1) Raise Car in The Rear Support it Good on Jack Stands.
#2) Remove your Wheel or Wheels if Doing Both Sides.
#3) Now Right in The Center of Your HUB you'll see a Dome Cap Remove the Cap,Now Remove the Cotter Pin, then the Spindle Nut and Washer.
#4) Now you'll pull your Hub Assembly Off ,The Outside Bearing will more or Less Fall off the Hub.But you'll need to Remove the Outer Bearing Race Its the Metal Angled Race.
#5) Before you remove the Outer Race take a Seal Remover and Remove The Grease Seal on the Inside of Hub.
#6) Now the Inner Bearing Will Come Out.You NOW Can Remove Innner and Outer Races.Use a Puch and Hammer Lightly Tap it by Working your Punch Side to Side.
#7) Now You've Remove BOTH inner and Outer Bearing Assemblies.
#8) Before you Start to Install New Races ,Get some Brake Clean and Clean The Inner Hub and the Spindle Good.
#9) Use a Bearing Race Installer Tool to Tap your New Bearing Races in.NOTE: you Don't want to Scar the Beveled Part of the Race Cause thars Where your Bearings Rotate.
#9) Races are in : Now take a Wheel Bearing Packer if you have 1 Availible: If not Pack As Much Heavy Duty Hi Temp Bearing Grease Into the Bearings. And Put some on the Spindle Were your Bearing Run on.
#10) Now Using a Seal Installer Tap your Inner Grease Seal into the Inner Hub Housing.
#11) OK Now your Ready to Put Your Hub Back on:Note: Put a Little Grease in The Domed Cap after you've Got the Hub On.
#12) DON"TS Get Grease on your Brakes or anywhere in The Brake Pad Assembly. #2) Don't Use the OLD Cotter Pin Get a New One. :#3) When Adjusting your Spindle Nut Don't Under Tighten or Over Tighten==Just Snug it down where theres no Play when you Take your Hands 1-Top=1 Bottom and Make Sure theres No Play.
Rotate The Hub During And When Tightening your Spindle Nut.
Put Hub Grease Cap on and Whell or Wheels and you Should be Good to Go.
Thanks for Using Fixya Please let me Know the Quality of my Advice/Solution by Voting Thank You From: d_hubbs
Jul 23, 2010 | 1993 Mercury Topaz
Wheel bearing noise coming from the front wheels
Pull wheel bearing from hub and check them after cleaning for pitting. Check each bearing roller a full 360 degrees for missing surface area and races as well. A race is what the bearing rides in and is pressed into the rotor/hub. They can be checked
without removing the race just clean the grease
and inspect for missing surface area cracking or
pitting. always put adequate amount of wheel bearing grease back and properly hand pack those bearings.
Feb 10, 2010 | 2002 Chevrolet Tahoe
Replace cups in Campagnolo rear hub
unless you want to ruin or warp your wheel id take it to a shop with a press or tool to do it right
Aug 24, 2017 | Cycling
Directions replace front wheel bearings on a 1985 nissan stanza?
NOTE: After the wheel bearings have been removed or replaced or the front axle has been reassembled be sure to adjust wheel bearing preload. Refer to the Adjustment service procedure below. On the 1989–92 240SX there is just one wheel bearing, pressed into the hub and no adjusting cap. Refer to the exploded views of the Front Axle Hub Assembly. Review the complete service procedure.
  1. Raise and support the vehicle safely.
  2. Remove the front wheels and the brake caliper assemblies. NOTE: Brake hoses do not need to be disconnected from the brake caliper assemblies. Make sure the brake hoses are secure and do not let caliper assemblies hang unsupported from the vehicle.
  3. Work off center hub cap by using thin tool. If necessary tap around it with a soft hammer while removing.
  4. Pry off cotter pin and take out adjusting cap and wheel bearing lock nut.
  5. Remove wheel hub with disc brake rotor from spindle with bearings installed. Remove the outer bearing from the hub.
  6. Remove inner bearing and grease seal from hub using long brass drift pin or equivalent.
  7. If it is necessary to replace the bearing outer races, drive them out of the hub with a brass drift pin and mallet.
  8. Install the outer bearing race with a tool (KV401021S0 special tool number) until it seats in the hub flush. NOTE: Place a large glob of grease into the palm of one hand and push the bearing through it with a sliding motion. The grease must be forced through the side of the bearing and in between each roller. Continue until the grease begins to ooze out the other side through the gaps between the rollers. The bearing must be completely packed with grease.
  9. Pack each wheel bearing with high temperature wheel bearing grease. Pack hub and hub cap with the recommended wheel bearing grease up to shaded portions. Refer to the illustration.
  10. Install the inner bearing and grease seal in the proper position in the hub.
  11. Install the wheel hub with disc brake rotor to the spindle.
  12. Install the outer wheel bearing, lock washer, wheel bearing lock nut, adjusting cap, cotter pin (always use a new cotter pin and O-ring for installation after adjustment), spread cotter pin then install the O-ring and dust cap.
  13. Install the brake caliper assemblies and bleed brakes if necessary. Install the front wheels.
Jun 23, 2009 | 1985 Nissan Stanza
Loose rear wheel, believe it is the bearing. How do I repair it?
drum brakes you remove rear wheel- speed sensor-grease cap-flange nut-outer bearing-brake drum-inner grease seal-inner bearing-drive the bearing races out of the drum hub.to install -install the inner and outer bearing races.apply grease to the bearings and hub cavity.then you install the inner bearing -inner grease seal-brake drum-outer bearing-flange nut torque it to 159 to 192 ft lbs. THE REAR DISC BRAKE WHEEL BEARINGS-you have to remove rear wheel -wheel speed sensor-brake caliper and rotor-rear axle hub bolts-tone the wheel with tool 09445-21000-carrier assembly-nut after unstaking it-press out the rear axle hub-remove the bearing inner race with tool 09445-21000-remove the bushings from the carrier with tools 09453-33000b and 09545-21100.to install -press in the bushings to the carrier with tools 09453-33000b and 09545-21100- press in the bearings to the hub with tool 09221-21000.tighten the flange nut to meet the concave portion of the spindle-press in the tone wheel with tool 09221-21000-torque the nut to 191 ft lbs -install the hub and bearing assembly to the backing plate and torque the bolts to 88 ft lbs-install the brake caliper and rotor.install the wheel speed sensor if equipped.install the rear wheel.TO BUY THE TOOLS TO DO THE JOB.LOOK UP KENT MOORE TOOLS ON INTERNET.
May 30, 2009 | 1999 Hyundai Sonata
Specialized Crossroads Logo
54 people viewed this question
Top Specialized Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
ddfisch
Level 1 Expert
John Egan
John Egan
Are you a Specialized Cycling Expert? Answer questions, earn points and help others
