Question about Baby Gear
How do you use a babystart baby carrier forward facing? Do you still put there arms under straps
2 Suggested Answers
SOURCE: Adjusting straps on baby carrier
hi. here is the website that may be helpful to you..
https://plweb.evenflo.com/replacement_parts.aspx
Posted on Feb 19, 2009
Combi instruction
It depends on your car seat. Follow your instruction manual for your child seat and your car. Not all seating positions have tether anchors.
"Rear-facing only" seats do not tether (these have a separate base and carrier)
"Rear-facing convertible" seats may tether.
"Forward-facing" seats usually tether (some MUST tether).
Jul 19, 2014 | Eddie Bauer Baby Gear
Maxi Cosi Pria 70 ****** strap too tight
Make sure your son does not exceed the weight limits for the forward facing harness. Do not put your child in the harness wearing bulky clothing, but use a blanket or poncho in the car instead of a snowsuit or winter coat.
Jan 03, 2014 | Maxi-Cosi Baby Gear
I need instructions for the genki house baby carrier and for the bubba moe baby sling
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
  1. Hold your baby close to your chest
  2. Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
  3. Still holding baby close to you, place sling straps over your shoulders.
  4. Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
  5. Thread the strap through D ring with one hand whilst your other hand still holds the baby.
  6. Simply 'hook' the strap through the D ring with your index finger.
  7. Do not change hands at this stage.
  8. Tension strap backwards - away from your back and don't let go.
  9. Feel the baby's weight now firmly supported by the sling at your waistline.
  10. As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
  11. Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
  12. Check the position of the baby - you should be able to kiss his/her head.
  13. Baby can also face outwards when he/she gets older.
Jun 15, 2011 | Baby Gear
Have been given babystart 0-1 car seat but havent got the instructions on how to fit into tfront facing
This video shows how to fit it. Different name from babystart, but exact same carseat. Hope this helps! http://www.youtube.com/watch?v=GKHtqOpzX8g
Apr 04, 2011 | Baby Gear
Can't make Baby Bjorn Active Comfortble
Use the size adjustment buckle to produce a comfortable fit for you and your baby. (The Baby Bjorn Active Baby Carrier is adjustable both for the baby and the parent). Make sure you are using BOTH adjustments, rather than merely adjusting for one or the other of you. Think of it as putting on (and tying) two separate shoes. Both should be nice and snug. Every review that i have said says these are never as comfortable as a wrap, but seem to be more convenient.
  • Step 3 use-bjorn-active-baby-carrier-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/ur/dd/use-bjorn-active-baby-carrier-1.3-800X800.jpg'); }); Unbuckle one or both of the side straps when taking the baby in and out of the baby carrier. This makes the job much quicker and smoother and everyone will be much more content.
  • Read more: How to Use a Baby Bjorn Active Baby Carrier | eHow.com http://www.ehow.com/how_5205421_use-bjorn-active-baby-carrier.html#ixzz0wKrU4VJb
    Mar 13, 2010 | Baby Bjorn Active Baby Carrier
    We have a babybjorn baby carrier. Our daughter is
    You may want to check that the adjustable strap at the bottom front of the carrier is at the proper position for the height and weight of your child. She shouldn't be slouching in the carrier. The carrier is designed for the legs to be slightly spread apart or 'frog legged' but she shouldn't be in a 90 degreee stradle.
    Hope this is helpful.
    Mar 03, 2010 | Baby Bjorn Active Baby Carrier
    Im not sure where to put the straps on me with my baby boppy sling?
    you have to put the straps over your shoulders so that your baby is not facing you
    Aug 08, 2009 | Hotslings Poppy Baby Sling/Wrap
    Feb 14, 2009 | Evenflo Baby Gear
    I can't figure out how to convert my snugli from baby facing inward, to baby facing outward
    If you are using the same one that I have...you put it on the same way as if the baby if front facing against you instead you place the baby outward and the piece that would normally support their head folds down in half away from you and the 2 straps that supported the head now holds that piece folded down and gives the baby added support when you lean forward. I hope this helps if not post another problem and I will try to explain again. Good Luck...
    Jul 03, 2008 | Evenflo Snugli Front & Back Baby Carrier
    Purple legs
    Which way is she facing? I have a 9 month old baby boy and this doesn't happen, and he is a little hefty! I am wondering if your lower straps are too tight. If she is facing forward, does she lean forward having the material cut into her legs? Maybe that causes the circulation loss. I always have my son face inward. He likes it more and it is more natural.
    Jun 30, 2008 | Baby Bjorn Active Baby Carrier
    Baby Gear Logo
    158 people viewed this question
    Top Baby Gear Experts
    Dorel UK
    Dorel UK
    Jennifer Rock
    Jennifer Rock
    Are you a Baby Gear Expert? Answer questions, earn points and help others
