Question about Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac
Where do i find the Valet switch - Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac
Where is valet switch located on 06 Pontiac g6 coupe
Valet switch ? What type problem are you having ? no valet switch
Feb 16, 2016 | Pontiac Cars & Trucks
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
Mar 06, 2014 | Viper Vehicle Parts & Accessories
How to program a ezsdei474 remote to a viper 130xv
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
Car starter in valet mode
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
Dec 07, 2013 | Dodge Cars & Trucks
Where is the valet switch on my remote controller
The K9-Eclipse has a push button valet switch. The switch is about 1/2" in diameter and about 3/8" in height. I can be installed anywhere but it is usually under the dash.
In order to activate valet mode, you need to push and hold the button for 3 seconds while the system is disarmed. Valet mode will be confirmed with a long siren chirp and the LED illuminating.
Valet mode can be deactivated by pushing and releasing the button.
Sep 23, 2012 | Excalibur. K9-ECLIPSE 2-Way Keyless Entry...
Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
Aug 21, 2012 | 1995-1997 Chevy Tahoe Ignition Starter...
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
My glove box valet lock is on, how do I override
Your black ended driver key should open the glove box. The valet key is not made to open it, thats the safty feature in it. There is no overide for the Valet settings, you have to unlock the glove box with Driver (master or black) key and turn the Valet switch off. Also the Valet switch does not engage the glove box lock so over riding the Valet security wouldnt open it even if you could over ride. If the Valet key would unlock it or was easy to overide then it wouldnt be a very good safety feature. Best of luck, hope you can get it opened.
Jul 28, 2010 | 2001 Oldsmobile Aurora
Valet Switch/Button
Contact a dealer for the location of switch
May 02, 2017 | 2002 Mitsubishi Galant
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Logo
26 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Charles Osborn
handt729
Level 1 Expert
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
