Question about Toaster Ovens
No STAY ON feature on my Munsey m-88 toaster oven
How do I get it to bake?
  • 12 Answers
SOURCE: Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Posted on Feb 24, 2009
protek480
  • 1723 Answers
SOURCE: how to remove grease splatter from toaster oven
Wrap the elements (gentle) in aluminum foil to keep the cleaner off the element. Then, just remove it when done!
Posted on Sep 18, 2009
Lady Spark
  • 51 Answers
SOURCE: after baking a pizza in a toaster oven the juices
I would suggest using a non-aerosol oven cleaner and applying it with a disposable brush. Wear rubber gloves. And, oh, unplug the toaster oven first...
Posted on Feb 07, 2010
SOURCE: Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Posted on Aug 28, 2010
  • 67 Answers
SOURCE: The middle black knob on my toaster has been lost
Try this web address for a list of websites that sell oven parts. Hopefully you will find one that carries it.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Posted on Mar 17, 2011
How can I bake stuffed bell peppers in a toaster oven?
Set the temp you want, cook in foil , open at the end An use broil to melt cheese
Dec 13, 2017 | Toaster Ovens
How do I disassemble a Toastmaster Toaster Oven model 340B to access the controls/wiring/switches section?
You can't. The lawyers think it is too risky for consumers to attempt repairs. Even those who are competent to do so.
Jan 14, 2017 | Toaster Ovens
Cancan I use a foil baking tray in the severin 220 rotisserie toaster oven
You should read the booklet which comes with Severin toaster oven. They can write everything which type foil we should use in oven.
Spit Roast Catering
Jan 25, 2014 | Severin to2015 toaster oven for 220 volts
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    After baking a pizza in a toaster oven the juices from the meat and cheese spilled onto the bottom of the oven, will water and vinegar work?
    Feb 05, 2010 | Toaster Ovens
    Kitchenaid kco1005 toaster oven broken timer dial/knob
    My kitchen aid toaster oven when set on baking the light is not coming on.
    Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
    Burnt pie
    YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
    Apr 13, 2009 | Toaster Ovens
    What is exactly a toaster oven?
    A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
    Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
    Toaster Ovens Logo
    Top Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Toaster Oven Expert? Answer questions, earn points and help others
