Question about Raypak UNITHERM GOVERNOR KIT
Unitherm Governor not opening
Is this ok or would is cause the high temp 2 error?
2 Suggested Answers
adamh294
  • 310 Answers
SOURCE: i'm getting an HL1 reading
Possibilities:
1-low water flow (this heater needs 45 GPM minimum to operate safely
2-blocked heat exchanger (flush exchanger through drain ports)
3-Unitherm Governor (already replaced)
4- Bad bypass assembley or bypass spring (these bypass assembleys do fail occasionally)
Id start with making sure the water flow is proper, and if that checks out ok, id replace the bypass spring and assembley.
Note: when examining bypass assembley, if spring is worn or missing, start with this only as its cheapest)
Posted on May 09, 2011
My ray pack RP2100 is flashing HL2 what does it mean
HL2 = High limit switch 2 is open. The switch opens if water temp inside the inlet/outlet header exceeds 135 - 140 F.
If you reset the heater and the HL2 does not reset, then the HL2 is likely faulty. When you order a high limit, there are 2 types on these models. Red (135 F) or black (140 f).
If you reset the heater, the HL2 resets and the heater fires for a short time, then the problem is likely with restricted water flow inside the inlet/outlet header.
Check the Unitherm Governor (thermostat) and the Internal Automatic Bypass Valve.
If you are uncomfortable with this type of repair work, a good service technician can be a wise investment in not only your time but the safety of you and your family.
http://www.troublefreepool.com/threads/27601-RAYPAK-DIGITAL-POOL-HEATER-INOPERATIVE
Mar 07, 2015 | Pool & Spa
Pool heater 406A unitherm governor
make sure connected correctly not enough water passing through if you have a bypass close half way if no bypass check the maual bypass in heater might be damaged or stuck
Sep 15, 2014 | Pool & Spa
What is aunitherm govenor
thermal regulator...located inside the heaters water manifold. its spring loaded and contracts based on water temperature
Jun 04, 2014 | Raypak UNITHERM GOVERNOR KIT
Need to install unitherm governor
Replacing UG is easy on polymer (plastic) header. Very difficult on metal. On polymer header you will find UG behind a cap located adjacent to where the plumbing goes in and out of heater. Take a long screw driver and use the shaft of the screwdriver in the grooves of the cap to unscrew it from the header (counter-clockwise). The UG should come out with the cap or be just inside and easy to grab. There is two clips on the cap that will hold the new UG while you screw the cap back in. The gasket isn't super important and even the manufacturer has said it can be left out, but it can be held in place with a couple drops of lubricant to make it easier if you want to use it.
Apr 04, 2014 | Raypak Pool & Spa
My raypak heater lights, but does not heat the water.
Yes, there is a bypass, and it is controlled by what they call a unitherm governor. That is a fancy word for a thermostat, very similar to the one in your car. It sounds like yours may be stuck open, or the spring buggered out. They aren\'t too hard to check out if you are handy with a wrench. It is located right where the water pipes attach to the heater.
Dec 28, 2012 | Raypak Pool & Spa
I'm getting an HL1 reading on my Ruud pool heater 206A. just replaced the unitherm governor, but it is still showing HL1. it will work for a while, then HL1 shows, then it starts again. what's...
Possibilities:
May 07, 2011 | Raypak Free Hydraulic Lift Gate Delivery -...
2002 wj jeep grand cherokee p1756
The governor pressure sensor is the most likley cause however an inspection of fluid or debris in trans pan would be a good idea to make sure there's nothing excessive in it. Attached is a list of possible causes however the senor would be the most common.
POSSIBLE CAUSES
  • Powertrain control module
  • 5 volt supply circuit open
  • Check transmission fluid level and condition
  • GOV press sensor signal circuit shorted to voltage
  • GOV press sensor signal circuit shorted to sensor ground
  • GOV press sensor signal circuit shorted to ground
  • GOV pressure sensor signal circuit open
  • Sensor ground circuit open
  • GOV press sensor signal circuit shorted to voltage inside transmission
  • 5 volt supply circuit open inside transmission
  • Intermittent governor pressure solenoid
  • Internal transmission problem
  • Oil burnt or oil pan has excessive debris
  • Other transmission DTC'S
  • GOV press sensor signal circuit shorted to sensor ground inside transmission
  • Valve body
  • GOV press sensor signal circuit shorted to ground inside transmission
  • GOV press sensor signal circuit open inside transmission
  • GOV press sensor ground circuit open inside transmission
  • Governor pressure sensor (high)
Mar 26, 2009 | 2000 Jeep Grand Cherokee
Raypak UNITHERM GOVERNOR KIT  Logo
51 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
