Question about Crosley Audio Players & Recorders
Needle crosley cruiser - Crosley Audio Players & Recorders
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
Do I need to replace the battery and buy a converter, or buy a completely new one? Is it completely broken?
Normal the high input voltage should influence the output voltage. The120V AC to 9V DC will be blown, but with a bit of luck, your Crosley cruiser will be ok. Only if the power convertor is poorly made, the high voltage could have gone through the convertor and then it damaged everything in the cruiser. Try a new 9V power supply and see what it does.
Jan 19, 2015 | Crosley Audio Players & Recorders
Dragging sound
If it is happening while playing, the needle if off balance and / or needs a new needle.
Aug 28, 2014 | Crosley Audio Players & Recorders
HOW DO CHANGE A STYLUS ON A CROSLEY CRUISER CR8005A
Type Crosley CR249TA User Manual " into search engine and it will show sites to get manual. In manual there are instructions to help you.
Jul 08, 2014 | Crosley CR249TA Turntable
Looking for cartridge/needle/stylus...
If you type Crosley Cartridge into Amazon, the type you need will turn up. Price around $20.
Apr 24, 2014 | Crosley CR6007A Turntable
What is the replacement needle for crosley cr74
Here i have added two links which will take you to the needle for Croslye CR 74. There you can also fined the code for the item
LP Gear stylus for Crosley
LP Gear 78 RPM stylus for Crosley
Dec 09, 2012 | Crosley CR74 Turntable
Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Dec 26, 2008 | Crosley CR248 Turntable
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
