Question about Garden
My zmax 25hp 60" mower blades won't turn on when I pull up to engage the blades??? Any ideas?
3 Suggested Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
  • 711 Answers
SOURCE: My Zmax 25hp mower blades won't turn on??? Any
Check battery connection and all wiring going to blade engagement switch. if there is a reverse kill switch make sure it is off.
Posted on Apr 22, 2014
What is the Function of the pto control
It is to supply power the electric clutch that drives the mower deck.
If not functioning then the switch, PTO clutch, or wiring is not working properly. Note on some ZTRs when both handles are in reverse then electric clutch is disengage for safety.
Oct 06, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
My Zmax 25hp mower blades won't turn on??? Any ideas
Apr 19, 2014 | Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
One blade is grinding the dirt when they are engaged
First check for a bent blade Then check for a broken spindle. Then check for broken metal on the deck or a broken/ disconnected deck hanger.
Oct 24, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
How to change mower blades
fine a way to stop blade from turning, put a socket with long handle and turn countercock wise, some will need a wench on nut at top of shaft to stop blade from turning, torque to 60 # on most 50" or lower width mowers
Mar 21, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Sep 17, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
My huskee lawn tractor will not turn over! The battery is fully charged, it is a 25hp with a 50inch cut, i replaced the selnoid last year!
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
May 09, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
