Question about Acer Aspire 6530-5143 Notebook PC
Sound problem Similar to the poster above - sounds like a crackling noise - does get worse when on battery. Also does it when using Skype.
  • kyzc2001 Jun 20, 2009
    It still does it regardless of whether I use the internet or not. I have BitTorrent but it is not currently running. I do not use all of these applications at the same time.
    Sergeant:
    Champion:
  • 253 Answers
Shut down any file sharing applications or internet software that consumes a lot of bandwidth and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
Disney pixar car tv dvd combo's sound makes a crackling noise
If you hear it with the sound off something is arcing, if not a sound problem.
Nov 01, 2012 | Televison & Video
My dell pc fan make a loud noice
There are 13 possible noise on hardware issues
1) Power supply crackling sound
2) Fan sound that sounds like a motor noise dragging
3) Harddisk clicking sound
4) CD rom spinning sound
5) Modem noise pinging sound
6) Application software resident in memory
7) Technician Neighbour drilling holes from your ceiling to do
special wirings late at night, installing transformers
8) Ceiling fan with unstable modified electricity makes noise
on motor issue
9) Sound that comes from switchboxes and transformer
upstairs lighting up free electricity from your fan wires
in your apartment unknown to you tapped by upstairs
residents
10) Voltage regulator malfunction noise issue
11) Monitor crackling sound issue
12) Wirings crackling sound issues
13) Power socket crackling sound issues
Be sure you know where the source comes from, call PC vendor if you are uncertain, you will have to dismantle your
hardware device in vendor's place to find out. Vendor will test one by one.
If computer fan is your issue, it is just a small issue
there are many replacement at PC vendors based on quality
corresponding to the price you pay
Nov 01, 2012 | Computers & Internet
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Intermittent crackling sounds DPR 1005
This is an obvious thermal problem. Use circuit cooler to isolate the bad part. It could also be a crack in a circuit board.
Alternate warming with hair dryer and cooling one component at a time while listening for the noise.
Feb 16, 2010 | Harman Kardon DPR 1005 Receiver
Screaming crackling noise when very hot
Crakling sound is a symptom of loose or cold solder in amplifier section where the STK IC or Darlington transistor is located .You better re solder all parts joints there in order the crackling sound is gone.
Hope it may help you;
Regards;
VOTIT
DON'T FORGET TO RATE;
Jan 08, 2009 | Audio Players & Recorders
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Crackling sound
Hi, the problem could be in your phone line, A solution I found was a free download from CNET called "Noise Free Voip"
This is a small download that runs with Skype etc and works very well at reducing outside noise factors.
Regards mistyman
Nov 01, 2007 | Intel Frontier Design Dakota 24-Bit PCI...
Soundcard problems
I'd say to look at latency settings and sample rates. also disable screen savers and power management.
Jul 09, 2007 | M-Audio Delta 66 Sound Card
Acer Aspire 6530-5143 Notebook PC Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
