Question about Refrigerators
How to hook up ice maker
How to hook up water line to sink
fridgetech
  • 473 Answers
SOURCE: Ice Maker
Most of the samsung's have a reset button on the bottom front of the ice maker that just pushes in and it should start the cycle.
Posted on Oct 22, 2007
hotuna
  • 288 Answers
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
At the back bottom of the fridge there will be a coil solenoid. If your appliance is ice make ready this will be there, these coils have a bracket that has fitting for a water connection. Get a 1/4 tube with a ferrell and nut. slide them on the tube and connect to the fitting.
Posted on Dec 06, 2007
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: Brand new Kenmore refrigerator, ice maker does not work
According to the manufacture, you must wait 24hrs to reap the benefits of the automatic ice maker. I was helping a friend the other day install a water line to a side by side unit that had been running for well over a week and after turning the water on we got no ice. We contacted the manufacture and they said "there is a 24hr waiting period". This makes no sense. I wasn't trying to get a gun permit, just ice.
Posted on Jan 13, 2009
  • 5370 Answers
SOURCE: ice maker stopped making ice.
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Posted on Feb 21, 2011
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The water is leaking from the ice maker . how can I turn it off, or close the tap
U can trace the line back to where it hooks in to water line and un hook it
Dec 19, 2012 | Refrigerators
How to install the water for the ice maker
To hook up an water supply to an ice maker falls under two catagories. The first being that a water supply valve is already present behind the machine and therefore all you have to do is get a water line, preferably a braided steel ice maker line that can be purchased at home depot or lowes. Then you just sonnect the water line to the water supply at the wall the to the water valve on the machine, located on the lower right or left side in the back. The second scenario is yoo don't have a supply line, and in that case your going to have to locate the nearest water line, most likely under the sink, and you'll have to run a line. They have an ice maker installation kit at home depot and lowes, and you may have to drill a hole through the cabinet to make the line unseen, or even through the floor and back up again. Either way its not a difficult task, just takes time and patience. Good luck.
May 10, 2012 | Frigidaire Refrigerators
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
I just hooked up the ice maker to the water line and put the lever down on the icemaker. The water has not filled the ice maker. Is there something I need to do further? The model # is 596.765 73600
  • here are some things to check for, please be very careful and only to this if you disconnect the power supply.
  • 1 Inspect the shut off arm located on the side of the ice maker. This arm should move up and down with a slight resistance when pushing upward. Make sure that this lever is not frozen to the side of the ice maker preventing it from dispensing ice. In addition, if the arm move loosely up and down, then it is broken and must be replaced.
  • 2 Verify that the ice maker is receiving water. Check the water supply valve which is usually located either behind the refrigerator or under the kitchen sink. The knob should be turned all the way clockwise until it will no longer move.
  • 3 Move the freezer or refrigerator out from the wall and locate the water supply line. This line extends from the water supply valve that was previously located. Make sure there are no kinks or twists in the water supply line as this prevents the ice maker from getting water. Also check for leaks along the supply line which will also prevent the ice maker form working.
  • 4 Locate the manual shut off button for the freezer, if it has one. In some models, the shut off button is located inside the freezer door. If this is the case, simply check to make sure the button is switched to the "on" position. Shut off valves are only on some Kenmore refrigerator/freezer combination appliances.
  • 5 Measure the temperature in the freezer by placing a thermometer inside and allowing it to sit for approximately one hour. If the temperature is higher than 17 degrees F, then something is wrong with the main freezer and not the ice maker.
  • 6 Check the water inlet valve to ensure that is allows water to flow through freely. First turn off the water supply at the water supply valve, usually located under the sink or behind the appliance. Locate the water inlet valve by following the water supply line up to where it attaches to the refrigerator or freezer. Turn the plastic nut at the base of the supply line counterclockwise to detach the supply line. Pull the two or four wires of the water inlet valve off of the terminals. Inspect the wires for burn marks or corrosion. If these are present, it means they must be replaced as water is not being fed to the freezer.
  • good luck
    Iain
    May 02, 2011 | Kenmore Refrigerators
    I have a water line thats cut off and dont know where its supposed to hook up to
    If you are referring to the ice maker water supply it usually connects to the hot water line of the kitchen sink by using a saddle valve like the ones that come in an "ice maker connection kit"
    Jun 24, 2010 | Refrigerators
    Ice maker water inlet keeps running
    Replace the water inlet valve. It's on the back where the water supply hooks.You can turn the water off usually under the sink.
    Dec 10, 2009 | Roper Refrigerators
    What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
    go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
    it will also contain step by step instructions.
    You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
    enjoy your new icemaker.
    May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
    Apr 22, 2008 | Refrigerators
    Refrigerators Logo
    21 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
