Question about LG DLEV833 Dryer
My lg delv833w dryer wont start says clean lint filter
I hit the start button and it says clean lint filter i did and i unplugged it and held the start/pause button for 8 second plugged it back in and same message appears
SOURCE: Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Posted on May 06, 2007
SOURCE: LG DLG 5988 Gas Dryer Does not heat and does not dry
same exact problem for a year and a half now....soooooo frustrated with a 1000 dollar dryer.  NO LG
Posted on Aug 12, 2008
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
omaharox
  • 166 Answers
SOURCE: the check filter light keeps coming ob to my lg
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Posted on Jan 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have an lg dryer model DLG5966W and the check
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Posted on Jun 17, 2010
LG dryer DLE2140 error CL clean filter which I have done and even used vaccum dryer still wont come on
the clean filter just blinks at start of a cycle to remind you to clean it. there is no lint filter sensor or anything like that. it goes out after you program your cycle and hit start. if dryer is not coming on, there is another issue. any fault/error codes?
Mar 10, 2015 | LG Dryers
Wont start
Ok here is a secret most of the time when you open your machine, you will find the service manual in it. It will take you through "the on board diagnostics". After doing this you will test if that sensor that monitors your lint filter is the problem. order the new part through Amazon.com. If you can't find it in your machine then look through the internet for it, you'll find it. i found it with Amazon but they wanted $25.00, i know if I had time, I'ld find it free.
Apr 19, 2014 | LG DLE0442 Electric Dryer
Our LG DLE0442W electric dryer is now flashing the Check Filter light and will start, but only run for about 5 minutes before shutting off. I have cleaned the lint trap completely and have also tried...
Clean any lint that got by the filter as best you can. If you can, get into the housing that surrounds the filter and clean it, but be careful not to damage the moisture sensor.
Check that the duct (behind the dryer) is clear of excess lint and has no obstructions (kink, bird's nest, etc.).
Good luck
Feb 21, 2011 | LG DLE0442 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
CHECK FILTER
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 06, 2010 | LG DLE5955 Dryer
LGDLE0442W Dryer check filter light on. Flter clean dryer sounds like it wants to start but doesn't. Is there a reset button?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | LG DLE2514 Electric Dryer
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
DLG2532W - LG Gas Dryer - Not spinning/working
COULD BE A DOOR SWITCH A THERMAL FUSE A CONTROL BOARD OR A MOTOR
YOU'LL PROBOBLY NEED TO CALL FOR SERVICE
Feb 22, 2008 | Dryers
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
LG DLEV833 Dryer Logo
21 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
