Question about Air Tools & Compressors
My mintcraft 2 hp 6 gallon air compressor is making this humming noise when I plug it in how do I fix it
2 Suggested Answers
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Posted on Nov 26, 2008
My kobalt 80 gallon air compressor won't turn on
BE CAREFUL! Jump the pressure switch and see if it starts. If so, replace the switch. If it doesn't start but hums, cut the power and try to turn the compressor by hand. Free it up if possible. If it does not hum, look for a reset on the motor or a blown fuse or breaker.
Dec 14, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
My Black bull 4 gallon 5.0 CFM 2 HP air compressor will not start. Regardless of whether the on or off position is selected, all I get is a humming sound for about 2 seconds, then it goes silent. After a...
I need the diaphram in the On/Off pressure switch on a Black Bull- 4 Gal., 2 HP, 5.0 cfm @ 90 PSI 120 v /13.8 amp . Batch # 0911. These are the only # I can find
Jan 19, 2013 | Black Bull Air Tools & Compressors
I have a Craftsman 33 gallon vertical air compressor with reduced noise motor. After not using it for a couple days, it won't start. There is power to the motor. Turned the pulley with power on in both...
The HP is to low for the 33 gallan copasity of the tank 6 hp is not enough If you are trying to run things that draw a large CFM . The disgin of the mechine is incorrect sorry its one mans oppoin the thing can't do what it says it can
Apr 07, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a 2 hp 4 gallon twin stack mint craft air compressor. I need the oil cap/ breather plug and also need to no how much and what kind if oil to put in the compressor
30 weight Non Detergent Air Compressor Oil is what you should use, although any 30W Non-Detergent Oil would work. Quantity wouldn't be much since it's only 2 HP. As far as the breather plug/oil cap, you caould try FD & Sons Hardware @ 866-612-5454. They showed as being a Mincraft Distributor.
Aug 18, 2010 | Garden
I have a Cleman 4 Gallon, 1.75 HP, Powermate air
When mine hums and trips, it is one of two things, Not warm enough, only does this when it is cold out, and 2 would be not enough juice, I have to have a 20 amp breaker or it doesn't run. And if I use a cord, it has to big. The slightest drop in amperage and it will not run, yours might have the same problem, mine is only 1 1/2 HP. It draws some 16 amps at start up and then idles down to 13 to run. A 15 amp breaker, forget it. Cold out, forget it. It wasn't just mine though, we did a house last winter and made one bathroom heated with a gas heater with 3 compressors in there just to keep them warm, there was no room for us. Hope this helps.
Jul 20, 2010 | Coleman Powermate 11 Gallon Air Compressor
I hsve a Husky 1 gallon tank 10 max psi mod # FP 202900. I was using it the otherday when it all at once started making a little noise then quit. I have unplugged it hoping it would reset, but no such...
There should be a reset button on the motor. Try that first. Otherwise, it is a bad pressure switch or internal motor problem. If resetting the motor allows the unit to start, but it just hums, shut it off right away, bleed off all pressure and try again. Let us know what happens.
Oct 21, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
47 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
