Question about Black & Decker Toaster Ovens
Tro4000 door switch broken
How do I repair
What can I do as my oven stopped working yesterday whilst heating up .Both hotplates work. No lights coming on oven switch. No fan working. Help please
If the oven is not working, the fan is not working, and the light is not working, it suggests that the oven switch is faulty as that is the only common part for all 3 things. It might be a broken wire or a faulty switch. You will need to dismantle the oven to gain access to the switch and then use a multimeter to test it. if you do not know how to do this, then get an electrician or oven repair company to help, as there are dangerous voltages inside an oven than can give you a shock or kill you.
May 23, 2016 | Russell Hobbs 13824-10 Mini Kitchen with...
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
I recently bought a Euro-Pro convection toaster oven and the timer switch has already broken. How do I get another one?
Call 800.798.7398. After polylingual promts, Select promts for "how to repair/replace your product", "Ninja or other kitchen appliances." Katie sd will send 3 knobsin the mail free of charge within 7-10 business days.
Jun 13, 2012 | Euro-Pro Toaster Ovens
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Dec 15, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Toaster oven door
Try sales@semenedis.com They do thousands of parts for white goods.
Dec 03, 2008 | Black & Decker CTO9000 Dining-In Toaster...
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Toaster Ovens Logo
24 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
