Question about Medion Computers & Internet
Mouse cursor not there - Medion Computers & Internet
Mouse does not move cursor, button works though
It could be the light, but have you tried using a different less reflective surface?
Feb 17, 2014 | Quill AirObic Mouse - Right / Left Hand
Why is cursor jumping using Gmail or Facebook on windows 8
Your OS is out of date and now obsolete. Win 10 has the patches you require for stability.
Jun 09, 2017 | HP Hewlett Packard 2000-410US 15.6"...
Enlarge mouse cursor size in iBook G4
Go to system preferences then to universal access, then click on the Mouse tab and you will see For difficulties seeing the cursor, you can then increase the size of the cursor. Hope this helps.
Apr 21, 2012 | Apple iBook G4 Mac Notebook
My wireless mouse - cursor refuses to follow sometimes!
Try cleaning the lazer on bottom with a q tip with some rubbing alcohol on it. Check to make sure the reciever for the mouse isn't too close to any wireless router,phone,or microwave. In the control panel there are mouse settings you can play with too to see if that makes a difference. Re-install any software for the mouse.
May 12, 2010 | Computers & Internet
Cursor jumps all over with a touch of the mouse why
trackballs and other ball mouses have an optical sensor inside the cup that holds the ball. dirt, lint and debris that falls into the optical sensor can make the cursor jump around - the sensor detects the debris as if it were a ball movement. Clean the inside of the cup and the jumping should stop.
Cleaning the cup -- first clean the three points that hold the ball up. They tend to grap whatever dirt or grease gets onto the ball from the user's hand. Clean the rectangular sensor window with a que-tip or by blowing into it. Get any stuck debris out of the corners. Finally, turn the mouse over, without the bal inside, and tap it on a hard surface. This can knock loose any remaining debris that can fall into the sensor window.
Dec 11, 2009 | Logitech Trackman Marble FX Trackball
How can i change my mouse cursor??(flower)to the normal pointer just the arrow one..
ok fallow these steps
clike start menu>settings>control panel>mouse>pointer>go to scheme and select none and apply changes.
your mouse cursor will become normal.
regards
gaurav rajput
Feb 12, 2008 | Computers & Internet
T20 cursor frozen
Computer mouse help and information A mouse is a hardware device which allows the user to control a cursor to manipulate data .... CH000981, The wheel on my mouse is not working properly.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
E-mail CHID: 6268 This feature enables you to move a mouse cursor or use mous buttons using ... also possible that your keyboard could be bad, causing the keys not to work.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T20 Notebook
Wireless mouse
I just read one of the other solutions, and it was to try and press the reset and mouse reset buttons together - woked for me! yay!
Louise
Dec 08, 2007 | Belkin Optical Mouse F8E850-OPT
Logitech mouse problem
sounds like you have reverse mouse enabled  go into the control panel find the properties for you mouse, this should be a check box you can disable.
Oct 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Trouble pairing my bluetooth Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Computers & Internet Logo
11 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
