Question about Gateway Computers & Internet
Como sacar el disco duro de la laptop gateway pav80
Sacar el disco duro para remplasarlo
WeListen2You
  • 538 Answers
SOURCE: Notebook Sony Vaio VGN-FJ270
La única manera de hacer esto es hacer una recuperación de sistema en el disco, si se asume que esto fue fijada realmente y funcionamiento. ¿si no, usted tiene un respaldo para estos datos?
Posted on Oct 23, 2008
mastericpr08
  • 571 Answers
SOURCE: Actualice la bios de mi Laptop Toshiba A665, el
Tiene que verificar con el lugar o pagina web por la cual actualizo el bios.
Posted on Dec 29, 2010
Keynan
  • 977 Answers
SOURCE: buen dia no soy una experta con la portatil pero
Hola!
Necesitas instalar el Lenovo Care Pack por Windows XP... Descargalo de aca.
Tambien, te recomendo actualizar el BIOS. Descarga la ultima edicion de aca.
El Rescue and Recovery tambien sera util... Descargalo de aca (version en Espanol).
Suerte y saludos desde Israel,
Pelu.
Posted on Feb 05, 2011
bronk50
  • 27725 Answers
SOURCE: mi laptop no enciende, solo las luces yel disco duro trata de arancar per cero pantalla
google translate
My
laptop will not start, only the lights andthe crank or start hard drive is zero per pantallaenciede lights but the screen is hard not crank or
start
, the fan turns on, heat near the fan, try turning it on without battery and no hard and without ram but not there results
answer
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Posted on Jul 15, 2012
Compre una imac m6498 pero cuando la prendes aparese una carpetita con una carita seguida de otra con un signo de interrogacion que puedo aser para que funcione
Normalmente el simbolo que mensionas sale caundo el sistema no purde encontrar el disco duro. Pera verificar si es el disco duro que esta fallando o no, completamente apages la computadora. Oprime el boton de poder e imediatamente oprime el boton "Option" y mantenga la tecla selecionada. Esto le senala al sistema que quieres ver todas las seleciones para butiar. El sistema debe mostrar un imagen del disco duro si no esta fallado. Si lo ensena, puedes selecionar el disco duro con el mouse o usando las teclas de direciony oprimes el buton "Return" or "Enter".
Si ningun imagen aparece o mas importante, si no muestra el imagen del disco duro, eso indica que el disco duro ha fallado y necesesitara re-emplaso. El sistem de OS X necesitara ser re-instalado con todos sus aplicaciones tambien.
Jul 18, 2011 | Apple iMac G4 Desktop
ACABO DE ADQUIRIR UN COBY MP727, SI ACEPTA LA CARGA POR MEDIO DE LA COMPUTADORA PERO NO RECONOCE EL USB PARA EL ENVIO DE MUSICA
tiene que o?r el equipo hace un ruido cuando se conecta el USB en el puerto. si esto no ocurre, usted tiene un puerto USB muertos. si usted est? escuchando el ruido cuando se conecta el USB a la computadora luego contin?e con el siguiente p?rrafo.
si est? usando Windows XP, vaya a "Mi PC" y el dispositivo debe aparecer como otro disco duro, al igual que tu (Disco local (C:)), disco duro interno. Usted puede abrir este al igual que una carpeta y desde all? debe ser capaz de colocar la m?sica en el dispositivo.
Jan 09, 2011 | Coby MP727 MP3 Player
EN LA PORTATIL ACER ME LEE EL DISCO SIN PROBLEMA, PERO CUANDO CONECTO EL DISCO USB PORTATIL VERMATI EN MI CPU CORE 2 DUO QUADZ ESTE NO LO LEE
Apreciado endor74,
Tu disco duro externo podria estar averiado o tener la tabla de ficheros corrupta. Por favor descarga la siguiente aplicacion de Seagate para verificar si es por motivos de hardware:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Si no te indica ningun problema de hardware, te recomiendo que utilices la siguiente aplicacion de OnTrack para intentar recuperar los datos todavia accesibles:
http://www.ontrackdatarecovery.co.uk/data-recovery-software/easyrecovery-lite/
Si no aparece ningun dato como accesible y recuperable, entonces solo queda la opcion de formatear el disco de nuevo. Te recomiendo esta guia que puedes seguir paso a paso para formatear el disco:
http://www.ehow.com/how_6026_format-hard-drive.html
Cordialmente,
Eddie Knight
Dec 28, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Tengo una Nueva Acer Veriton M460 core 2 duo, vista bussines,Disco Duro Seagate 320GB, se hizo downgrade a Win XP PRO, no funciono, volvi a recuperar disco duro, hize lo mismo y no funciono, instale el...
La instalación del HP Compaq no funciona en la máquina nueva porque el sistema (hardware) es completamente diferente.
La mejor manera de hacer el "downgrade" es instalar el sistema operativo desde el comienzo, borrando cualquier partición que exista, donde está el sistema operativo instalado que no funciona. Para eso se necesita el CD o DVD con Windows XP SP2. Esto se hace activando la opción en el BIOS de la PC para que lea el CD o DVD antes que el disco duro. Una vez dentro del programa de instalación, hay que descartar la instalación anterior borrando la partición y volviendo a crearla, usando los íconos del programa.
¡Buena suerte!
Dec 01, 2009 | Acer Veriton M460 Micro Tower Core 2 DUO...
Al encenderlo lo unico ue funciona es el ventilador, ue inmediatamente se apaga, no lee el disco duro ni el CD, la pantalla no presenta ninguna informacion sigue completamente negra
Asi parece un problema de placa base.
Para empezar quite la bateria y deconecte el adaptador para resetear la ordenadora.
Intenta remover disco duro, el unidad CD , la bateria, y si el ordenador tiene dos modulos de RAM quite un modulo y intente arrancar el portatil con esta configuracion minima de perifericos, con el adaptador enchufado.
Si el laptop no aranca asi, usted probabilmente tiene un problema de placa base.
Aug 14, 2009 | Toshiba Satellite M35X-S109 Notebook
Como le quito el password al bios
para sacar la password de la bios de la maquina solo tienes que abrir la maquina, al lado de la pila en la placa madre hay un jumper(un plastiquito que sirve de conexion)lo tenés que cambiar al 2-3, esta gralmente en el 1-2, osea lo sacas, lo pones en el 2-3, prendes la maquina unos segundos, la apagas, vuelves a cambiar el jumper a la posicion 1-2 y listo tu bios queda borrada, ahora solo tienes que entrar a la bios y configurar tu disco duro, la hora, etc,etc , si no hubiera tal jumper, entonces directamente sacas la pila por unos segundos, la vuelves a poner y listo,
Jul 15, 2009 | Toshiba Satellite L25-S119 Notebook
Unidad para disco duro SATA serie hitachi modelo
Sin importar el Sistema Operativo, este problema está relacionado con si el tablero principal de su sistema tiene o no los conectores necesarios para su unidad de disco SATA. La fuente de energía (en sistemas modernos) trae al menos dos cables de poder de este tipo, y dos más para IDE. Los cables SATA para la transmisión de los datos se compran por separado.
Si su sistema es de varios años de edad, es muy probable que no tenga ni los conectores SATA salientes de la fuente de poder para conectarlos a su nueva unidad, ni aquellos que se requieren para conectar el disco al tablero.
Una manera de hacer que funcione un disco SATA en un sistema que carece de sus conectores SATA es algo o muy fácil, o algo caro, pero ambos factibles.
1) Fácil: Compre un adaptador de SATA a IDE y conecte la nueva unidad de disco al adaptador, y luego éste al terminal existente IDE en el tablero. El único problema aparente es que no va a aprovechar de la velocidad mejorada del disco SATA.
2) Es posible que alguien venda un controlador SATA para estos sistemas, aunque personalmente no he visto un solo anuncio en las revistas que cubren la industria. Es muy probable entonces que esta opción no exista.
3) Una mejor solución es reemplazar el tablero por uno más moderno, aunque se corre el riesgo de que se necesite cambiar también otros componentes como la memoria, etc. lo cual no podría ser económico, pero se quedará como un equipo del último grito, dependiendo de cuánto esté dispuesto a gastar. Eso sí, si llega el momento que los componentes separados le cuestan más que un sistema nuevo, entonces esta última es su mejor opción.
Jul 12, 2009 | Computers & Internet
Ibm 06p2525 alguien podra decirme como configurarla para que inicie desde el CD de instalaciã³n de XP pues en el bios, no viene opciones de arranque. Y ya probe con F1 hasta la F12 y ninguna me...
El disco de instalación y su programa que usa (¿windows XP home?) son muy diferentes y lo que usted quiere hacer no va a darlo ningún beneficio. Déjalo todo como se fué diseñado. Aunque si podría hacer esto el resulto estaría una computadora muy lenta porque se va a tener partes que mueven. En muy poco tiempo necesitarái un disco duro nuevo y un drive de CD-DVD. Tiene una mente muy inteligente, pero deja estas cosas en vivo. Déjame que te doy una precaución. No juega con la tarjete madre, porque es una cosa muy delicada, sino que no estás preocupado pagar cómo US $ 300- 500 dólares y labor de mano de igual, porque quemastes la targata madre. No tengo más tiempo explicarlo pero mantenga sus dedos fuera de esta cosa tan delicada. Muchas gracias para la consideración y opción de nuestro servicio. Mi nombre es Constantino )arzconst es mi contraseña interna con Fixya.com=
Jun 13, 2009 | Computers & Internet
Tengo una DN hd2500 y se bloquea
bueno, la cosa esta asi, basado en lo que a mi me ha sucedido, yo uso la dn2500 y  le doy mucho uso, a mi me *** ese mensaje varias veces, db save ng! , cant acces, eso es cuando tu disco duro esta fallando o ya murio o no lo puede encontrar, pero cada ves que me paso eso fue llegando al lugar de trabajo, me volvi loco , desconecte el teclado y la volvi a prender y se solucionaba hasta que un dia no arranco mas, entonces saque el disco duro interno y lo quise poner en una caja para copiar la musica a otro disco duro, hecho esto volvi a poner el hd en su lugar y funciono, yo creo que es un tema de los conectores, pero tambien podes ir a utilidades y probar hacer una base de datos nueva. lo importante es sacar la musica que tenes ahi, despues te compras otro disco duro($40) y lo cambias por el que esta ahi adentro o lo usas por usb externo, recuerda que el usb externo tiene que estar formateado en fat 32. aca esta mi email por si necesitas algo matosfilms@gmail.com
May 04, 2009 | Denon DN-HD2500 MP3 Player
Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Computers & Internet Logo
16 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
