Question about Siemens Microwave Ovens
E16 fault, flashing time clock - Siemens Microwave Ovens
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
How to set clock please
They're all different.
But usually there's a button that says "CLOCK".
Press it in and hold it until the display starts flashing just the hours. Set the hours, then maybe press the clock button again and maybe the minutes will be flashing.
Or maybe on your oven, once you get the time flashing , you can set both minutes and hours with the number buttons.
Like I said, different manufacturers have different instructions.
Mar 16, 2015 | Microwave Ovens
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
User manual for E16 fork lift truck
I don't think that's a microwave.
Jul 14, 2014 | Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
I have a John Lewis combination microwave which I believe is made by panasonic. The microwave is brand new and I get a flashing "ErC" message at random on the front panel. Do you know the reason. This is...
I have exactly the same problem with 2 of the JLBICO2 microwave ovens straight out of the box. With the first oven, the service agent who looked at it thought it might be a faulty sensor and recommended replacing this together with the PCU. John Lewis have replaced the first oven and are in the process of replacing the second unit within a couple of days. Hopefully the third time will solve this issue.
Oct 23, 2010 | Panasonic Microwave Ovens
The clock is flashing all zeros - cant set it
Press: Stop cancel
Press: Clock or Autostart (depending on model)
Set time
Press clock or autostart.
Should have the time set......
If this is too generic pleae provide a make and model and I wil see what the manual says verbatim.
Kelly
Aug 21, 2010 | Microwave Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave Ovens Logo
94 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Bill Olaschinez
Bill Olaschinez
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
