Question about Apple iPod nano chromatic
My ipod isn't working
Has a connected eject before disconnecting thing on it it says its on hold but its not time is frozen it says its charging but its not even connected
  • 33 Answers
You should try to reset the firmware by pressing on the menu button and the enter(center) button at the same time for couple seconds until the apple appears on the screen
reconnect your ipod and with itunes try for any firmware updates
once it's done disconnect your ipod with itunes and after that with the windows option in the taskbar.
Good luck
Posted on Jun 19, 2009
My ipod is frozen. "Connected eject before disconnected."
Hello, if it's still frozen try holding the power button and the center of the scroll wheel, or the power button and the top of the scroll wheel until it restarts, then try re-connecting it again.
Nov 30, 2009 | Apple iPod nano
Failed to eject before rebooting computer, now USB port says it doesnt recognize the ipod and my ipod is frozen on "Connected-eject before disconnecting"
Actually this issue shouldn't really be that difficult to resolve. :) A simple reset should take care of it being frozen on the connected screen. Below I have posted a step by step on resetting an iPod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
As soon as you see the apple icon appear disconnect the iPod from your computer. After the iPod completely loads. reconnect it to make sure it is connecting and loading correctly. If this does not resolve your issue for any reason please do let me know. I have a few other options we could attempt. :) and the feed back is always good. It lets me know if I am actually helping people with they're issue's or not.
May 16, 2009 | Apple iPod nano
Frozen ipod
Hey i scored you these instructions on how to reset your frozen ipod. Hope its hella useful. Good luck :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Apr 23, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
Apr 19, 2009 | Apple iPod nano MP3 Player
Ipod screen says connected eject before disconnecting shows picture of charger but won,t do anything the time is stuck the battery isn,t charging help
I had a temp problem like this too! I found that by purchasing the plug adaptor, it got around to charging the battery on the iPod eventually. Check that the points of the USB cord at either ends haven't been bent or are at least clean.
Apr 05, 2009 | Apple iPod nano
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
I Pod 4 Gb
Just charge the battery until the indicator says the battery is full.
well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 18, 2008 | Apple iPod nano
Apple iPod nano chromatic Logo
216 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
