Question about Kohler Miller 907209 Bobcat 225 Welder Generator
Part number for grommet on a Miller 225 Bobcat fuel line at tank
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: How do you drain the
Hi pplmelita,
If you don't have a petcock to turn the fuel off below the tank, I would disconnect the line at the filter and drain the gas out that way.
If you're wanting completely drain all old gas out, drain as above and then run until dry.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 14, 2011
I have a Miller Bobcat 225. It will not start and run with out pouring gas into the carb? I have changed fuel line and filter? Help!!! Please
Check fuel pump and check carburetor bowl for stuck needle. If fuel was left in engine stuck needle or plugged jets. Confirm that choke is fully closing when cold.
Hope this helps?
Fuel Pump.
Jun 26, 2017 | Miller Welding Tools
Gas will not circulate through the fuel line
ethanol gas.... probably turned your fuel line to jelly
Mar 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Miller gasoline tank leaking from meter
Depending on machine model and sn you need to order the fuel gauge repair kit from a distributor. It will have all of the parts needed and instructions on the removal and installation of the new part. This is a commom problem that we are seeing with the Bobcat and Trailblazers. I can drop ship the part from Miller to you if needed. Feel free to contact me at (803) 609-8518 William Scott.
Jun 12, 2012 | Bobcat Miller 225 Welder Generator 907209...
Have a 225 bobcat welder wont stay running can add fuel to carberator but if i stop sparing fuel in unit stops??
The fuel pump is one of the probable faults, or the needle valve in carb is stuck in closed position.
If the fuel hose is removed at carb, it should squirt gas as the engine is cranked over. If not, look in tank to see if the screen on the barb threaded into the tank has not clogged up with debris. If it is clean, replace fuel pump.
If it squrits gas- open up the carb and check to make sure the float is able to pull the needle valve down as well as the float level setting. When the bowl is exposed, look for sediment as well.
Jan 03, 2012 | Bobcat Miller 225 Welder Generator 907209...
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
New fuel pump but won't pump fuel
start from the geginning. fuel tank- trash water etc. fuel line, valve open line not plugged, caberator clean and float not stuck closed. use air to blow lines out. good luck
Sep 02, 2010 | Bobcat Miller 225 Welder Generator 907209...
Kohler Miller 907209 Bobcat 225 Welder Generator Logo
201 people viewed this question
Top Kohler Welding Tools Experts
Bill Boyd
Are you a Kohler Welding Tool Expert? Answer questions, earn points and help others
