Question about Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
Clutch/break will not disengage
Starts and runs cant disengage parking brake
2 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: zero turn mower, starts fine, but shuts off as
It may be the park brake switch, but check the wiring for the seat sensor switch too.
Posted on Nov 27, 2009
Parking brake stuck
First off, I'd make sure the car was in park with the engine off and try that but I assume you already tried with it both OFF and ON. On should never work unless your foot is already fully engaged on the break. as many cars will not allow you to release the parking break unless you foot is on the break, some will not even allow it when the engine is not running, even in park. If you are running and the foot is on the break. Try SLOWLY moving backwards or forwards to disengage it since you may have pulled it a bit too far and the cable was real tight, this is easier to do when that parking break is too loose to begin with, and once the car rolled it got even tighter but moving the vehicle in the opposite direction that it rolled may loosen it enough.
If all else fails, you or a mechanic may go under the vehicle and simply loosen the cable to disengage it and then re-tighten it. Even if you are able to loosen them yourself you may want a mechanic to tightening the parking brake since is common chore for mechanics and it should not cost that much to do since it literally take only a few minutes once on the lift.
Apr 15, 2015 | 1999 Mercury Villager
Gear shift stuck in park
You should take your car back to the person or place that you fixed it and tell them it is worse than before. Insist on getting your money back if it is not fixed.
Jul 12, 2017 | Ford F-250 Cars & Trucks
Clutch does not disengage gears
You either have a hydraulic clutch system or cable. What probably happened is your hydraulic system failed. You either have a separate reservoir for the clutch master cylinder or it shares the brake reservoir. Check under the hood next to you brake master, Too difficult to answer without more info on year, make and model.
Dec 15, 2013 | Garden
The parking break won't disengage on my Lincoln Ls 2003.
Try checking the fuse for the parking brake. If that doesn't work check the ground meaning you might have to remove the cover were the parking brake button is. If that's not it you have to have someone check the parking brake cable which is located behind the brake caliper in the rear of the vehicle. Sorry for the long novel just giving you the most common things before it drives you crazy. Hope it helps if anything just post again and ill b glad to help you again. Thanks good luck.
Feb 24, 2013 | Cars & Trucks
Engine runs good but dies when brake/clutch is let out . This happens with me on the seat,in neutral,parking brake in off but continues to run with parking brake in on position, and motion control lever in...
well the not moveing could be the brakes are rusted look were the break rod goes put some wd40 on that its on the side of the trans and you will need to move back and forth to free it up and the cluch break switch is bad i hope this helps you
Mar 07, 2010 | Husqvarna Garden
Can i disable the headlights on in the daytime on my 2000 suzuki gran vitara, i am going through headlight bulbs very often and they are 20 dollars a pop.
They only activate when the car is in gear and the parking brake is disengaged. find the grounding wire off the parking brake lever and break the ground when brake is disengaged, you may also lose you parking brake warning light. Not sure if it's on a seperate circuit or not.
Oct 14, 2009 | 2000 Suzuki Grand Vitara
Clutch cover wont go back on
the easiest way i have found to put the cover back on is to take the clutch drum off.now youn can put the cover on.reset the brake and reinstall the clutch drum.the brake loop gets in the way any other way.hope this helped,if not let me know and we can try something different.......
May 10, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
27 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
