Question about Oreck Vacuums
My oreck xl21 won't pull itself. - Oreck Vacuums
  • Oreck Master
  • 932 Answers
You need to rotate your brush or replace the brush. Lay your Oreck down, unplugged with the base plate facing up. Remove the 5 screws that hold the plate on and remove the plate. Look at the bearing blocks at each end of the brush, what you are going to be3 looking for are a series of "hash" marks on the black plastic mount. If you see several, rotate the block until you only see one mark at each end and reinstall the brush and belt and that should take care of your issue. If you only see one mark, you need a new brush roller. Hope this helps!
Posted on May 16, 2015
How to replace the belt on an oreck XL21 vacuum
There's a Pannell on the side onevno2 philips head screw remove that and there is the belt
May 12, 2014 | Oreck XL21 Bagged Upright Vacuum
How do I replace oreck xl21 fan?
That nut is a left handed thread, so you need to turn it like you would normally tighten it to actually loosen it. You will also need to hold the shaft at the other end with some pliers. I would suggest using a piece of cloth or leather over the shaft so that you do not scar the shaft when you grab it with the pliers. Hope this helps!
May 07, 2014 | Oreck XL21 Bagged Upright Vacuum
Wreck xl21 will not stay in upright position
Your detent needs to be replaced. You can go to Oreck.com and search their store locator to see if there is a repair store near you.
Mar 16, 2014 | Oreck XL21 Bagged Upright Vacuum
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Is there a height adjustment for bare floor to thick carpeting?
The XL21 has a 2 speed switch use the lower speed on bare floors.The XL21 does not have an adjustment mechanism.
Jan 28, 2011 | Oreck XL21 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
Where do the cotter pins go on an Oreck upright vacuum? Thanks. Sally from Lake County, Ohio
I called the Oreck Company in the late night. They are in service 24/7. The employee instructed me on where the cotter pins are attached. Glad to help someone.
Jan 07, 2009 | Oreck XL21 Bagged Upright Vacuum
Oreck XL 21
My old vacume had the same problem - the wire had a 'plug' on both ends. 1 to the wall outlet and 1 to the vacume, which you could pull out of the vacume. It was making poor contact at the vacume and eventialy burned out (melted)
See if the plug/wire to the unit is removable, if so is it damaged?,
could need a cleaning, or it may not be pushed in all the way.
Good Luck
Mar 22, 2008 | Oreck XL21 Bagged Upright Vacuum
Vacuums Logo
90 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
