Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How do I connect Brother MFC5440 CN to my computer
How do I connect this to my computer- only has power lead and telephone wire - where & how do i connect? thanx
  • 33 Answers
When you buy scanner and printer you have to buy a usb
If you don't have this cable you can click on the following link to get the usb cable
http://www.amazon.com/Belkin-F3U133-06-Hi-Speed-Cable-Six-Feet/dp/B00000J1TX/ref=sr_1_1?ie=UTF8&s=electronics&qid=1245426484&sr=8-1
there should be a square usb port behind the printer so you can plug the square usb
once it done install your multitask printer driver and this should work just fine
Good luck
Posted on Jun 19, 2009
  • 43 Answers
I would suggest USB - there is a little square connection usually on the oppisote side of the power.
Help connecting brother fax machine
1. Connect the handset.
Connect the curled handset cord to the bottom of the handset and to the left side of the machine.
2. Connect the power cord.
3. Connect the telephone line.
Connect one end of the telephone line cord to the jack labeled LINE on the left side of the machine. Connect the other end to a modular wall jack.
WARNING
 This machine must be grounded using a three-prong plug.
 Since the machine is grounded through the power outlet, you can protect yourself from potentially hazardous electrical conditions on the telephone line by keeping the power to your machine on when you connect it to a telephone line. When you want to move your machine, protect yourself by disconnecting the telephone line first, and then the power cord.
 Lightning and power surges can damage this product! We recommend that you use a quality surge protection device on the AC power line as well as on the telephone line, or unplug the lines during a lightning storm.
Dec 30, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I am recieving a comm.error when faxingit also shows memory full when the page prints
Hi
You usually get a Comm error due to poor performance of your phone line. Check for any visible issues with the phone line. Check whether the jack is plugged in properly and the wire is not cut.
If you are sharing the phone line then check that any other devices are not interferrring in device's performance. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
There may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Daniel Scott
Jun 26, 2010 | Brother MFC-8460N All-In-One Printer
Witch wire connects it to the computer cant find the hole...
The Brother MFC units with CN at the end of the model number can be connected in two ways.
  1. Via a network using an ethernet cable.
  2. Directly to a PC via a USB cable.
If you look at the user manual, it will explain how to do so. If you have lost the manual (and the drivers/software that came with it), these are available on the Brother website.
Dec 31, 2009 | Brother MFC-5840CN All-In-One InkJet...
How to hook up a pc computer
power lead
monitor lead
mouse lead
keyboard lead
are the ones that you must have. Optional are speaker, microphone, ethernet/internet, and telephone.
Nov 21, 2009 | HP Compaq Presario dv6693us Notebook
I just received fast access dsl via at&t and updated my computer to home vista, how do I connect by printer so i can send and receive a fax
Your printer is fax capable? If yes, you will need a telephone wire connecting the printer to a known good dial tone (read "telephone connection").
Sep 30, 2009 | Brother MFC 210C All-In-One InkJet Printer
The amplifier keeps on blowing out the fuse when i connect the battery
Start by dis-connecting the power lead at the amp, and securing it (where the bare wires are not touching ground) Now insert a new fuse then make the battery connection. If the fuse blows then you need to trace the power wire to find the short, or replace the entire wire, paying close attention to sharp edges and pinch-points that could cause this problem to reoccur.
If the fuse didn't blow, dis-connect the power lead at the battery then all of the other connections at the amp, reinstalling the power lead to the amp. With only the power lead connected at the amp and the good fuse inserted, reconnect at battery,and if the fuse blew then the problem is with the amp. and should be repaired or replaced depending on its value and the cost effectiveness of those two options.
If the problem has not yet been discovered, continue with tracing each of the remaining amp wires in that manner, as been described above.
Good luck...
Feb 23, 2009 | Directed Extreme XA-5001 150W x 1 Car Amp...
How does my copy machine connect to my modem
Here is the user manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Page A-9 in the appendix section shows you how to plug standard telephone cords into the fax machine.
Jun 17, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC5440 Does Not Print
A1: close scanner (this is NO error!)
Take carts out and reinsert. Make sure they are secured. Watch display and give answer (Cart changed? 1: YES).
May 13, 2008 | Brother MFC-5440CN All-In-One InkJet...
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Wiring problem
Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.
Orange/white
To lighting switch terminal.
Blue/white
To system control terminal of the power amp or
Auto-antenna relay control terminal (max. 300
mA 12 V DC).
Nov 30, 2007 | Pioneer DEH-P3500 CD Player
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
678 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
