FAN AND AIR MODES WORK BUT ON FURNACE MODE AIR COND. AND FURNACE BOTH RUN.
SOURCE: coleman mobile home electric furnace
Peace,
It seems you need hands on servicethis time !
ngafm
Bless You,
Please leave me a rating before you sign off!
Thank You
SOURCE: furnace will not turn on in Auto mode thermostat
It sounds like you T-Stat is messed up. Look in your manual to see if there is set up instructions. If not I would change the T-Stat.
SOURCE: Does this unit draw inside outside air in fan mode?
that's usually controled by a baffle inside or outside air
SOURCE: 2003 vw passat air cond blows warm air
Hi there. You have a freon leak in the system. You can charge the system and use soapy water on all joints to find the leak. If a slow leak, just recharge every year. This will get you by till you get the leak fixed.
Thanks
Paul
SOURCE: shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
