Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
GE JTP15 f3 error code - Kenmore 40494 / 40495 / 40499 Electric Single Oven
    Champion:
  • Kenmore Expert
  • 323 Answers
Posted on Feb 02, 2015
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
How do you replace and oven sensor in a JTP15 wall oven?Getting F3 error code and ordered the part today but it doesnt come with instructions.
You will need to shut off the power and remove it from the wall. Remove screw holding sensor from inside oven. Then pull rear panels off to access rear of machine, be sure to tie a string to the old sensor wires so that when you pull them through you can tie the new wires to that string to make it easier to pull them back through. Plug new sensor wires in, put oven back together and re-install.
Please rate my solution if it was helpful.
Thanks, Repairman45.
Dec 02, 2010 | GE JTP15 Electric Single Oven
I get an F3 error code on my built in gas oven, then it turns off
Hello,you have an open or shorted oven sensor.. check the sensor harness connection between the sensor and the oven control. make sure power is OFF.. if wiring is okay you have to replace the sensor . call for service would be the easier route just tell them what you will need probably be about 200 dollars though once complete.
Thanks
May 28, 2010 | GE JTP15 Electric Single Oven
F3 error code
you have an open or shorted oven sensor.. check the sensor harness connection bewtweenn the sensor and the oven control. make sure power is OFF.. if wiring is okay you have to replace the sensor . call for service would be the easier route just tell them what ur gonna need probably be about 200 dollars though once complete
Jan 28, 2010 | GE JTP15 Electric Single Oven
Oven lock f3 appears on pannel
Check on the internet for appliance fault codes, there are sites that list most brands and what the codes mean
Oct 24, 2009 | GE JTP15 Electric Single Oven
F3 Error code
I cleaned the contacts in the relays on the control panel. That fixed my problem
Jul 12, 2008 | GE JTP15 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
50 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
