Question about Sony Computers & Internet
Left mouse button on VGN-AR requires a lot of pressure to operate
The left mouse button (not the touchpad) on my Vaio VGN-AR51M still has the same travel and movement as it did when I bought it a year ago, and the same satisfying 'click' when pressed, however the button seldomactually works as it should do, clicking and dragging being the most irritating function, as it will frequently lose contact halfway through, or sometimes it will double or triple-click when I am trying to single click, and often requires a lot more pressure to function at all than it did when I bought it.
I use an external mouse when I can, and am not looking forward to sending my laptop back for repairs, as I require it on a daily basis. But ultimately, I would like to figure out what the problem is so I can fix it.
The mouse buttons are housed along the edge of the laptop, which makes them difficult to access, and I have not resorted to taking the case apart to see how they function yet. I dearly love my laptop, and this so far is the single only problem I have had.
Any guidance or assistance would be appreciated.
  • justin275 Jun 22, 2009
    Thank you, I had a feeling that taking the cover off would probably not help solve anything. I'll find a place to get it repaired post-haste. Many thanks for taking the time to answer my question :)
  • Sony Master
  • 2,404 Answers
On your model the buttons that you press on your mousepad are actual tactile buttons that are on the motherboard and they do wear out over time. The only way to resolve that problem would be to either bring it to a electronics shop where they can replace the tactile button on the motherboard or replace the whole motherboard itself which could get pricey.
Posted on Jun 20, 2009
Touch pad for sony vaio mp 5 player
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Sony Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 19, 2012 | Computers & Internet
I have a Sony Vaio and though the touch pad allows the cursor to move around the page it does not allow me to click on anything. I have a Logitech mouse that I use but that is because the touch pad is not...
You may need to enable the buttons for Sony Vaio Synaptics TouchPad as follows...
1. At the bottom left of the screen on the Taskbar, left-click on start.
2. On the pop-up window, left-click on Control Panel.
3. In the Control Panel window, left-click on Sony Notebook Setup
4. On the Sony Notebook Setup pop-up, left-click on the Device tab.
5. Left-click on Pointing Devices to high-light it, then left-click the Settings button.
6. On the Mouse Properties pop-up window, left-click on the Device Settings tab.
7. On the Devices listing for Synaptics TouchPad, left-click the Settings button.
8. On the pop-up window Properties for Synaptics TouchPad on PS/2 port....
9. Left-click on Buttons item to bring up a Buttons frame with an Enable buttons check box.
10. If the check box is not checked, left-click on it to enable the buttons for the TouchPad.
11. Left-click Apply button or OK button to enable TouchPad buttons and exit the pop-up window.
Feb 01, 2011 | Sony Computers & Internet
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
My left mouse button on sony vaio vng-nw150j isn't working
Generally, if a mouse button quits working, it requires the replacement of the touchpad assembly.
Boot to the safe mode, see if the button works there, if it doesn't, then it is a failure of the switch in the button
http://cgi.ebay.com/TESTED-Sony-Vaio-VGN-NW150J-LCD-Keyboard-Palmrest_W0QQitemZ120522991092QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0fbae5f4#ht_1088wt_1165
Jan 29, 2010 | Sony VAIO VGN-SZ460N/C Notebook
Two buttons beneath touchpad are not working
You should clean the button by opening the cover, realign it, and check if the button touches to the board.
Nov 12, 2009 | Sony VAIO Notebook PC VGN-NS235J/W
Sony vaio touch pad not working.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
Oct 28, 2008 | Sony VAIO VGN-SZ460N/C Notebook
Left mouse button and mouse pad sometimes stops functioning on the sony vaio vgn-ar51e
It's most likely a loose cable inside the notebook then makes contact intermittently. Or, your touchpad is faulty.
It might be worth having the machine looked at by someone certified to take it apart.
Sep 11, 2008 | Sony Computers & Internet
Computers & Internet Logo
1,032 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
