Question about Visioneer OneTouch 9000 Flatbed Scanner
Will not do final scan
Worked perfect everyday (ebaying) for months. Now does preview ok, but will not then scan.
Error message is 'unable to comminicate with twain device' or 'error encountered, Reset parametours and try again' but can't get anything to work.
Uninstalled programme and reinstalled. Still the same.
Installed on another computer, Still the same.
Don't know what to do next.
ps Source is correctly selected.
    Problem Solver:
  • 17 Answers
What version of windows are you using? Which software are you using to do the scan, and what version? It sounds like either the version of scanning software is incompatible with the version of windows, The USB connection (Assuming it is connected via USB) is a older USB connect (1.0 or 1.1) and a update to the firmware is causing a fault in the final scan, or finally the scanner has gone defunk... time to get a new one.
Posted on Jun 26, 2009
Scanning Slides from Epson Perfection V700PRO
Hi
Please reinstall Epson Scanner software it will solve your problem
Thanks
Apr 11, 2008 | Epson Perfection V700 PHOTO Flatbed...
Epson 3170 scanner - have been scanning fine for over 2 years now suddenly says 'unable to write to file' ?! Actually seems to scan OK in preview just will not write file....... any ideas ? Scott
Check to see where it is writing to (which directory) and make sure the directory exists and you do not have duplicate filenames. Check the free space on the drive you are writing to. Run an error check on the drive. If it is a shared folder/directory then check your permissions.
Mar 24, 2011 | Epson Perfection 3170 Flatbed Scanner
Scanning 110 negative film
I just finished scanning many 110 film strips. You need to lay the strip along the inside edge of slot A and scan in normal preview mode. On the preview strip, put a marquee around each individual photo and scan each one separately. Worked fine for me.
Sep 27, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Aug 07, 2009 | HP Office Equipment & Supplies
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Problem saving scanned negatives to laptop. Epson 2400 scanner.
If you are scanning in Color and in high resolution, then the file size will be very big. Try and close other programmes in your Laptop and try. If in color try 150 or 200 dpi option and also select JPG format. Alternatively you can increase your RAM in the laptop. S. Mohan
Nov 13, 2008 | Epson Perfection 2400 Photo Flatbed...
MP145 Scanning Problem
hi Fulminater.
this is all i could find out from the internet.
Scanner driver will be closed : Code 2250.
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
check can't work the scanner because the cartridge are not inserted.
this is all i could find out.
Nov 29, 2017 | Canon PIXMA MP150 All-In-One InkJet...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Scanner wont scan
I have an Epson Perfection scanner and it has always worked perfectly. Then, out of the blue, it completely stopped working. I cannot recall the error codes, but the solution I found was to uninstall/reinstall. I still don't know what occurred to create the problem, but it has worked flawlessly since the reinstallation.
Good luck.
Dec 22, 2007 | Epson Perfection 3590 Photo Flatbed...
Visioneer OneTouch 9000 Flatbed Scanner Logo
78 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
